- Joined
- Nov 3, 2003
- Messages
- 49,329
Sounds like it might be awhile yet before the new style holder gets into the Painless pipeline.
All current Painless setups, including yours will still have the single Maxi-Fuse holder for the cabin power. And you would have sourced your own Mega-Fuse holder for the charge wire.
If you don't already have the large charge cable and fuse, you could opt for the Midi size instead and then if you decide to change out the Maxi later to match, you would be half way there.
Even if you already have, and install a Mega-Fuse in the charge system, you can also change them out later if you decide you want to go that route instead.
No performance change in other words, just convenience and aesthetics.
But it's possible too that pricing for replacement parts will change as well.
Changing later, the Midi and Mega are probably a straight swap with no wiring change for the alternator charge circuit. But going from a Maxi to a Midi might require different crimped end connectors.
Personally even though I like the Midi, and it's a reasonable replacement for the charge wire, I'm not sure I prefer it over the Maxi for cabin power, or not. The Maxi is very compact and replacement fuses are available everywhere just like the Maxi and Midi. At least around here the stores carry all three I think.
Have not compared the cost of replacement fuses, but that does not always come to mind because I don't plan to replace a lot of fuses.
So for me it would come down to aesthetics of having two of the same, rather than two different holders.
Obviously I'm on the fence still. On the one hand it's very nice to have one style fuse fit the two different holders, but on the other the Maxi is very compact. And you already own it.
Guess it depends on how crowded your engine compartment is, or if your sense of balance is struck by having two identical fuse holders in a row maybe.
Either way you still have different rated fuses for each. One with 50 to 70 amp ratings, and one with 150 to 175 amp ratings.
If you already have the Mega Fuse and charge cable, then it's up to you if think matching fuse holders is important enough to toss out the old ones and buy new.
