4R70W calibration file
broncokak
Anyone using a switch to unlock the TC for something like a long hill clime on the hi-way?
chuzie
chuzie
Heck yes. It is always in use off road constantly on and off depending on situation. I need to install a light because sometimes I forget it is locked when I come to a stop and look like a boob when it stalls. I love it!
Sent from my Droid using Tapatalk 2
broncokak
Not off road, I want to be able to unlock the TC before the computer tells its to. Mostly to keep the rpms up a like on a long up hill grade as speed.
chuzie
chuzie
Ohhhhhhhh.
There is not a switch to force it to unlock. You can manipulate the TPS position at which it unlocks though but it would not be situationally dependent like you want.
chuzie
chuzie
The grounding of the brown wire just overrides the system and forces the converter locked. When ungrounded, it is allowing the system to determine converter logic.
DanWheeler
Kirkland, WA
I use a 3 way switch. On/Off/Auto. On grounds the brown wire, off opens the circuit so it wont lock and auto lets the computer decide.
chuzie
chuzie
So the info I got from Baumann must be incorrect if you can make the Brown wire work 3 ways. How is it hooked up for off?
Brown ground=lock
Brown not ground =auto
Brown ???=force unlock
Do tell. Are you applying voltage?
broncokak
I would think it would work exactly opposite of the manual lock switch on the floorboard. In this case though the torque converter is already locked. So if you open the circuit or break the brown wire the torque converter should unlock.
Brown ground=lock
Brown wire hooked up to computer only = Auto control
Brown wire disconnected from computer = never lock
Brown wire grounded = always locked
Brown wire hooked to computer and also hooked to switch (to ground) = auto with manual lock over-ride.
You should never really need a switch to force an unlock. That is simply you have not programed the controller correctly. Adjust the software will fix that.
The manual over-ride to lock is useful when you are pulling a decent grade and slipping the convertor severly. running too tall of a gear and the convertor always in multiplication phase. By locking the convertor you go to a 1:1 coupling in the convertor (almost no heat generated) and you can pick a gear that will let you drive up the grade more comfortably. You can also show off by doing hill climbs at idle with an automatic that no other automatic can pull off;D
chuzie
chuzie
Gotcha. Yep, I love being able to manipulate my trans temp on the trail via the TC lockup. Those hot days crawling around place me in the 200 degree range so I lock it up when I can and recover to 180 degrees. Friggin awesome. A cool trans makes me very happy. Albeit I am a bit fixated with the trans temp gauge!
broncokak
Heck, my F150 has the correct programming and there are tons of time I wish the TC would unlock a little sooner. It's all about the flexibility of being able to do so if needed. Now if you tell me it will damage the tranny, that's a different story. ;D
Macmillan
southern New Jersey
I know this has been asked many times before. Does anybody have a Calibration file that they can share. It sounds easy to prgram but I would be more comfortable with downloading a file, than playing with shift points and curves.
chuzie
chuzie
Here is what I have been running with 35" and 4.56. I'm pretty happy with it.
Save the file and make sure you rename it so the extension changes from PDF to BTC.
  • 4R70W_Bronco_Normal.pdf
broncokak
I uploaded chuzie's program and ran it today. It's pretty close to mine as far as shift points go. I'll do some more work on my program and then post it here too.
Thanks for posting your program.
