Years ago I did some research on trans operating temperature and what I found was that the coolest it should operate at needs to be
I know I saw some posts in the past but I’m wondering at what temp you would you be concerned enough to want to consider getting a trans cooler & what one did you go with , I also thought I read where someone mentioned replacing the fan clutch as well to help ?
5.0 Explorer motor & 4R70W
Thank you
warm enough to drive any moisture (condensation) out of the fluid. A little more poking around lead me to roughly 160°, so that's what I've been looking for myself and advising.
Several years earlier than that I encountered an article in a auto trans rebuilder trade magazine that had a graph of trans life-span vs. operating temperature. At 180° it was decades. At something like 275° it was single digit minutes. I'm not sure if in the intervening years that has changed much, but it sure left an impression on me! Broncobowsher's numbers make me think that maybe not a lot has changed.
If the trans cooling system that you've put together normally runs cooler than 160° I'd say celebrate it, and then consider putting a thermostat in the system. They're sold by most of the online racing suppliers (Summit, Pegasus, etc.) and they typically start to open at 160° and reach fully open at 180° In really cold climates I wonder if the ATF ever does get warm enough? I've long advised putting the aux cooler first in the system so that the radiator has the opportunity to warm up the ATF in those conditions just before it goes back to the trans, but there are valid points about making it the last in the system.
For most people, who aren't driving to the Artic Circle or operating a tundra buggy, in practicality it doesn't seem to matter.
