5.0 explorer replacement bolts
stretch
Montgomery, TX
Alright guys, I hope you can help me with this. I am missing or lost the majority of the timing chain cover, water pump bolts and plenum (sp?) bolts from my 99 explorer 5.0. I have gone the Ford route and these bolts are discontinued. Right now a Ford parts guy is trying to run down the sizes for me but he did indicate that each bolt that they can locate is in the 5-7 dollar each bracket. I can't see myself paying that kind of cash for 20 to 25 bolts. Does anyone have an idea where I can find the sizes and or replacement kits. I've already checked the Jegs/ Summit areas.
zeeman1
Seattle
That sucks man. Might be worth your time to rummangin around a junkyard if you can find one that has one of those guys.
Viperwolf1
electron whisperer
Water pump and timing cover bolts:
2 ea 1 1/4"
3 ea 2"
2 ea 2 1/4"
4 ea 3 1/4"
1 ea 4"
1 ea 4 1/4"
all 5/16" diameter
Go to your favorite hardware store and save some cash.
brewchief
If you want something nicer than hardware store stuff check out ARP, they should every bolt needed.
6daze
I know I have the upper plenum bolts on my workbench at home, will measure them tommorrow for ya....
bfoldy
Torrance, CA
2 ea 1 1/4"
3 ea 2"
2 ea 2 1/4"
4 ea 3 1/4"
1 ea 4"
1 ea 4 1/4"
all 5/16" diameter
Wow! Now that is an extremely helpful post. Nice work!
SC74
2 ea 1 1/4"
3 ea 2"
2 ea 2 1/4"
4 ea 3 1/4"
1 ea 4"
1 ea 4 1/4"
all 5/16" diameter
I wish I had that info when I put mine together. I took a trip to Ace and got everything I needed for the entire explorer set-up.
ransil
I was junkin yesterday and found 5 V8 exploder from the cash for clunkers, someone got all the heads & intakes off them and all the hardware was sitting in that battery trays, I might go back today if I do i will throw them in the tool box. Won't be able to get the timing cover & Wp stull cause that is the stuff I'm after.
ransil
Does anyone know the thread size of the harmonic balancer??
this is the 3 inside to put a puller on,I made a puller for it but not sure the size the bolts are.
its either 5/16 18 or metric something.
