I want to see if some one could help with few issues
, I have a 77Bronco.
1. Can the entire front accessories be kept on a stock 90's Mustang, if you use an electric fan setup which should provide more space in the front?
2. If I go with a carb setup, what distributor do I need? (can't remember which car some mentioned using)
3. The truck has a c4 auto trans, is the 50oz 164 tooth flex plate correct to bolt to the current torque converter? Does if come from a particular car which be helpful at the local parts store when looked up?
