Front end alignment help needed
Fitz24
Installed Duff long arms recently. Been driving a little and finding it a little more squirrly than before. Never had the alignment checked after original build so decided to take it to local shop to have it checked,
Looks like toe-in needs a little adjustment, along with camber and caster. Don't think camber is adjustable on D44 but know the others are.
My Bronco has 4 1/2" suspension lift. When ordering the Duff long arms they recommended installing new 7 degree bushings. Including PDF of the readouts from the alignment machine.
Looking for advice from our CB frontend specialist out there on what I should do to make it drive a little better.
  • img003.pdf
Camber, while in the red, is still good. That is the good place to be.
Caster is a touch light, but is on the correct side of zero. Not really anything you can do. The U-joint angle at the front pinion has got to be really close to binding if it isn't.
Negative toe (toe out) hurts. My shadetree alignment ways to crank the toe adjuster in about half a turn will get you pretty close. Remember one side is RH threads, the other is LH threads, you have to go IN to correct not out.
Now that is just the static angles. How the linkage is corrected for the lift plays in as well. And don't stop just with the front. The rear suspension can play games with you as well. A leaf spring bushing going away can cause a little rear twitch which can make the front feel unstable.
B RON CO
Statesville, NC
Hi, I agree the caster and camber are not bad. And the right front toe should come in to @ 1.5* toe in.
I don't know why the shop didn't do that.
Also make sure the air pressure is set a little lower. A lot of guys are good under 30 PSI.
Post some pics of the front end, there is usually room for improvement with trac bar angle and the way the drag link is set.
Good luck
Apogee
Tangent, OR
What size tires are you running? Given the details in your signature line, I'm assuming 35's or 37's, but please let us know so we have all of the information. Air pressure on the tires might drive better in the 26-30 PSI range from my experience, but it depends on the tires and weight of the rig.
As for the alignment specs, why didn't they tweak the toe-in on the rack? That's a quick and easy fix and should improve tracking significantly. With 35" to 37" tires, I generally aim for about 1/4" total toe-in.
More caster would help your tracking as well as the return to center, but probably cause problems with binding your front u-joint in use. I only have a 3.5" lift with CAGE long-arms (similar to Duffs), and with the built-in caster adjustment plus the 7 degree bushings, I could only get an offset u-joint to work...love how it drives, hate the offset u-joint. I'm currently in the process of swapping in a HP D44 where I intend to cut and rotate the knuckles so that I can have both good caster number as well as a good pinion angle.
Merry Xmas Eve
Fitz24
Fitz24
Thanks everyone. I'll get a picture of the frontend after I get home from work.
I only asked the shop for a reading so I knew where I was and see if anything was way out. They didn't charge for the rack time or readouts. Should have had them adjust the toe while there. Need to get steering wheel centered again and see if I can adjust right side in some. Running a Duff Heim Joint steering linkage and an adjustable draglink from WH.
Tires are 385/70r16 (37") Toyo Open Country on 10" wide rims. Running 20lbs of air.
I just installed a 4r70w and adapters which moved TC back 3.5". Front pinion ujoint angle looks pretty good and doesn't bind. No need for offset ujoints.
Fitz24
Fitz24
Uploaded picture of frontend and front pinion angle. If anyone has anymore input, it will be appreciated.
From what I have read, caster should be 2.5* to 4.5*. Some say 3* to 6*. Since I'm at 2*, would I benefit from changing 7* busihings to 4* bushings for a new reading of 5*? I hope I'm right in thinking lower degree bushings will increase positive caster.
Merry Christmas everyone.
Setting toe with that setup is a bit more difficult. There is no infinite adjustment that you normally get. take a heim off and do half a turn is the smallest change possible.
But the angles look pretty good. Make sure the steering box is tight to the frame and the frame isn't cracked, the same for the track bar drop bracket. It's welded to the frame?
You really don't adjust a single corner of toe. You set the overall toe and center the wheel. Right front is toed a hair out, that is because the steering is turned ever so slightly to the right while on the alignment rack. A very slight turn of the steering wheel to the left will fix the right front and move the left front to toed out.
As far as centering the steering wheel there are a few ways of doing it. The correct way for a modified rig like you have is to remove the drag link. Turn the steering lock to lock and come back to the middle between locks. Take the steering wheel off and install straight. Repeat to make sure you have it right. Reinstall the drag link and drive it. Adjust the drag link until the steering is centered. Adjusting the drag link will not make any changes to the toe. Only changes the relationship of the steering box to the tie rod. The tie rod is the only adjustment to the toe.
B RON CO
Statesville, NC
Hi, now I see why the shop didn't adjust the toe. So I use my friends
"toe plates" from his race car. You can figure out any one of many ways to measure toe. Basically, if the measurement behind the wheels is 58 1/2", and in front of the wheels is 58 7/16", you have 1/6" toe in. You would turn the right side (in your case) heim in 1/2 turn, measure again, and go for a drive.
Now you know how much a 1/2 turn adjustment will give you.
If you want to see how another 1/2 turn toe in feels, you can do that.
There is a thing about having the steering box centered and that is when the steering box is centered, it is like being set at the top of a hill. A little to the right or left, and it is rolling down hill. So it wants to continue down hill. It takes effort to go back uphill, so it is likely you overdo it, and now it wants to go downhill the other way.
Another thing I would try, after the toe is set, is drive without the steering stabilizer. It won't cost you anything. I always go for the cheap and free fixes first. Maybe it will feel good without it, or maybe a brand new one will make it better.
I'm not saying new caster bushings won't help, but I would work with what you have first.
Good luck
rafitz24
Thanks for all the feedback. I'll start with changing the toe-in a little at a time and see what it drives like.
Merry Christmas everyone!!
Sent from my SM-N960U1 using Tapatalk
mrdrnac
"From what I have read, caster should be 2.5* to 4.5*. Some say 3* to 6*. Since I'm at 2*, would I benefit from changing 7* busihings to 4* bushings for a new reading of 5*? I hope I'm right in thinking lower degree bushings will increase positive caster."
Sorry, but changing the 7 degree bushings for 4 degree ones would move you to the negative side (the wrong direction) you would be at about 1 degree negative. You are already at maximum correction on the bushings. And as others have said, your driveshaft angle may already be critical and may bind at maximum drop. The only way now to gain positive caster is to cut and turn the axle "C" ends.
In your picture your driveshaft angle looks really good............are you sure the 7 degree bushings are installed correctly???? Seems like your pinion should be down more with the 7 degree bushings installed correctly.
drroy
squirrelly steering is usually not enough caster 1.8-2 deg isn’t much. I have 3.5” lift and 33” tires. During my rebuild I replaced/rebuilt everything from steering wheel to tires. I cut and rotated knuckles to 6.5 deg pos caster (with 2deg C bushings). Wasn’t really satisfied as felt squirrelly, I then went to 7 deg C bushings bringing me to 11.5 deg caster. Which is a crazy amount but not unheard of on this forums ( I searched), I can take my hand off wheel at 60 mph and it tracks straight, with no appreciable increase in steering effort at low speed.
If you already have 7deg Bushings, you can buy camber/caster bushings for the upper ball joints on both sides to get another 1.5 deg bringing you to around 3.5. Deg caster. You will need to cut and turn knuckles if you need more than that.
Apogee
Tangent, OR
...In your picture your driveshaft angle looks really good............are you sure the 7 degree bushings are installed correctly???? Seems like your pinion should be down more with the 7 degree bushings installed correctly.
My pinion was virtually flat, maybe slightly down at ride height with the 7 degree bushings and CAGE arms, hence the binding issue. How certain are you that you have 7 degree bushings? Did you install them or someone else?
Fitz24
Fitz24
Did the cage arms have any built in caster? Duff arms are supposed to have 4* built in. How much lift do you have?
Fitz24
Fitz24
Yeah, realize I was going in the wrong direction with my thought process. Pretty sure I installed the bushings correctly. What change in caster would result from installing them backwards? Duff Long arms are supposed to have 4* built in caster.
EPB72
Pleasant Hill, CA
From the side view the arms installed you can see the bushings enough to tell how there installed ,,,the inner part of both c halves are shifted on 7 deg bushings its very noticeable look close you well see it and snap a picture to post as well
What EPB said. Look at them and if you aren't sure, post up some semi close-up shots of the side of the bushings.
If both bushings are installed backwards you lose the same 7 degrees you were looking to gain.
So in your case, with an additional 4 degrees built in to the arms themselves, you'd actually lose 3 degrees on your install. Instead of gaining the expected 11 degrees.
On many Broncos (most of them in fact?) gaining 11 degrees of positive caster over stock should show in a very low pinion angle. Not all are the same however, as we've found many times over the years. But it's consistent enough to have brought up the questions here.
bchesley
About 6 months ago I played with different C bushings installed backwards to point my pinion more at the transfer case. I was trying to get rid of binding at full droop. I ended up with a 2 degree installed backwards. I then cut and turned my knuckles so I have 7 degrees of caster. It now drives as straight as my modern vehicles. Seeing your pinion compared to mine in the photos I say they are backwards.
bchesley
Another angle. It would need to rotate up a few more degrees to be perfectly in line with TC.
Yeah, we got the pinion angle in your last pic. Now let's see some pics of the side of your C-bushings just to try to narrow down what's going on here. Whether it's your axle's fault, or something to do with the parts installed.
Imagine that pinion rotated upwards 11 more degrees and you'll see why we're questioning the install.
The pic leaves us with the assumptions that either the bushings are not 7 degree offset, or they're in at least half-backwards, or your pinion angle was originally at a crazy up-angle to begin with.
None of which are unheard of.
With a few images of the C-bushings as directly from the side as you can get we might be able to determine their offset.
Or hey, just leave everything as-is and have the yokes cut and turned to correct caster. Since your pinion angle is super nice right now, that's your best course of action anyway.
Unfortunately, you'd need to remove the C-bushings to get the best access to the axle ends anyway. So might as well start with pics of the C-bushings and move on from there as needed.
