For posting you either have to be a contributor, or upload images to a hosting site such as SuperMotors or PhotoBucket or similar, then post a link to the image.
For the hub, it sounds like you've got the main pieces that are required. Namely the two snap-rings.
Just to make sure though, are your locking hubs (lockouts) original to the 66? Did they have an flat faced center section of aluminum, with a simple raised ridge in the middle? Or were they something different?
If you are sure you got the only large ring out of there (a PO may have installed 2, but that would be pretty unusual I would think) and don't see any other possible impediments, maybe your splines are a little buggered or you just need to wobble the outer hub/drum assembly to allow the splined pieces to release.
They can be pretty hard to get out sometimes when the bearings are loose and things are floppy. And also when there is some rust or gouging on the edges of the splines of the outer hub.
Got most of the grease cleaned out of that front area so you can see better?
Good luck.
If you don't use the hosting sites, e-mail me any images you have and I can post them up for you.
