I'm not a mechanic and my only formal automotive education was one semester of High School Auto Shop in another lifetime; so what do I know? Anyway, here's my two cents.
Since a metal tube generally has a smoother/straighter finish inside where the liquid is, there is:
* Less friction loss from a smoother tube than one with ridges like in a rubber fuel hose where the nylon reinforcement creates ridges. Also, every
connection cause resistance in the flow especially when using ninety-degree turns/bends.
* Reduced turbulence in the flow (turbulence creates resistance and possibly micro air bubbles).
* A greater resistance of collapsing/pump under a high demand (big HP Engines) being sucked from the tank to the pump in the engine bay or from
a "Duck Butt" (pinching/kinking) that reduces the internal diameter of your supply when using rubber.
* Greatly reduced corrosion (depending on the type of fuel/chemical and the compatibility of the metal or metal coating in the pipe (be careful with E-85).
* Less likely to burn when too close to exhaust like rubber. Be fire safe! Also avoid boiling the fuel with metal tubing too close to the exhaust.
* If your pumping fuel from a pump in the tank to the engine you may also want to factor in the Head Pressure (gravity) especially with larger lifts (like a 5"
lift) with a small pump or you can use a bigger fuel pump to help offset this. Be careful when selecting a fuel pump and don't just look at the fuel
pressure rating (thinking about those fuel injected Broncos). You should also look at how much volume it pumps for your application, (thinking about
those 4-barrel Broncos) or you could find that your Bronco idles great but is starved of fuel on long acceleration or at the top end.
For some of you that like to relate things, you can think of it like helping your engine breath better with a less restrictive air intake and air filter. (since your engine is basically a big air pump). The smaller the air intake, the smaller (dirtier) air filter, the more connections, the sharper ninety degree turns, the less volume reaches your engine. It's kind of like the old pipeline goal of putting one marble at a time in the pipe and getting one marble out the other end each time. I hope this is more helpful for some. OK, since I let the cat out of the bag with air filters . . . . does this relate to those little two-dollar fuel filters (that love to clog or melt with E-85) you see near the rear drivers tire on some broncos (save those for your lawnmower)? The Coyote fuel filter on my F-150 is nearly the size of an old-fashioned coffee can. Food for thought, get it . . . coffee that fuels us. LOL
My personal experience with nylon (clear to having a milky white appearance, can turn a brownish orange with age) has a tendency to crack with age and long-term exposure to heat (I used to live in Arizona only to walk into my garage and smell gasoline in the direction of my 68 Jaguar E-Type). I also found that if you're inserting a barbed metal connection into the nylon tubing, soak the end of the tube in hot water a few minutes to soften it before you begin the wrestling match (not too hot or it will want to fold/crimp). I would highly advise to avoid heating with a flame/torch since there is really no temperature consistency and it's easy to melt (waste your materials/money. Also, when you buy the materials, buy the fresh stuff and not that antique stuff that's been sitting on the shelf for . . . since Hendy Ford walked over and put it there. LOL
My recommendation is to use the biggest compatible (type of fuel, like E-85) supply tubing/pipe without going crazy or you may find yourself with too little pressure, volume or both. Remember to "Go with the flow" that actually fits your particular application. I'd rather plumb my Bronco with a larger tubing now than wish I had it down the road when I want to upgrade. If I lost you, go to the coffee store and get a plastic stir stick (like a red swizzle stick) then go to McDonalds and order a shake (I like the chocolate shake myself). Suck the shake out of the stir stick then the straw that came with the shake and you should now understand Capacity, friction loss, volume and pressure. If you bend the straw ninety degrees, you can experience restriction. If you twist and bend the straw in a lot of places while taking a drink you will experience a kind of friction loss.
I'm thinking that I must have stayed at a Motel 6 last night (if you're old enough to remember those commercials)
OK, I need more coffer or better yet I'm going back to bed.
