Yeah, good luck with that. If it's torqued properly (75 to 105 lbs) then the old hammer-n-screwdriver method would be fairly destructive to say the least.
Luckily many of these were never put on properly in the first place, so can be manhandled off pretty quickly.
I'm guessing though that by now you've probably explored that possibility, if would even be accessible with the last bit of the lockout still in place.
When you push in on that clutch ring, can you feel it go in slightly and then push out under spring pressure to the same point each time? If so, I wonder if you could push it in and hold it while you use a file or anything you can get in there to chase each and every spline groove and edge to see if you can flatten out a burr or other defect that might be holding it back.
And like we were talking about with zacraig, have you tried wiggling the outer hub and drum up and down and all around to see if maybe a loose bearing is letting it bind?
Good luck with it. Don't have any of the usual suggestions like welding two bolts to it and using a prybar to twist the nut. Or using the same method to get a slide hammer on something to yank that sucker out.
