Clarification on Front hub/drum assemble
vtboy51
After way to much research here are the details on how to remove the front drums.
Ford (atleast in '68) took the front hub and stuck it through the drum, they then added a swedge around each stud, essentially making it a single unit. Unless you cut off the swedge around each stud the unit needs to come off as one.
But what is recommended by the suppliers is to use a hole saw and cut the swedge off, and then the drum can be separated from the hub, allowing for easy swapping of drums and internal parts.
So all the banging and lubing will not separate them, the swedge needs to go, or you are forced to remove the hub ever time you need to do brake work.
broncodriver99
Glen Allen, VA
Yes, you need to either cut the swedge or drive out the studs as was suggested in your other thread. In my opinion once the drums are cut the drums are no longer usable. The "swedge" or really in the case of the Bronco, interference fit as it is not an additional process like a swedge, are what keep the drums centered on the hub and was done for a reason. I would not suggest eliminating it for ease of service as you should rarely need to access the front brakes and if you do it is a good time to repack the bearings anyway.
When I was daily driving mine I got into my hubs and bearings WAY more often than I ever had to service the brakes.
I was forever adjusting the brakes of course (the automatic adjusters were not really reliable) but all that was done through the usual slot in the backing plate.
Not worth the trouble to modify the drum in my opinion.
And like 99 said, probably not a great idea. I think the brakes themselves would help to "self center" the drums, but to do that you'd always need a helper to press the brake pedal prior to you ever tightening down the lug nuts. And what happens when you just want to pull a wheel? Do you always have to go through the same centering procedure?
Or is the whole point to just trim enough off to keep it from locking on? Seems like an overly fine line.
And again, not likely worth the hassle.
vtboy51
vtboy51
Because of bad earlier advice on these threads and from JBG I hammered the hell out of the drums trying to get them to release, but just ended up breaking the edges. And that is why I have to do something now, and I'm trying not to spend the money to buy new assembled unit (hub/drum), but rather just new drums.
I don't quite understand the "centering" issues mentioned. Even if I remove the small swedge so the drum slides off (without removing hub), won't the new drum slide right on over the hub and onto the studs, ensuring it's all centered.
I have never seen a lug stud swedged into place. Press in is how I always see them done.
The oddity would be race cars that have been drilled and tapped for screw in. And the occosinal spinning stud that gets a tack weld to hold it in place so the lugnut can be removed.
I've popped more studs out then I care to remember. With the right feel they come out in a single hammer blow with no damage to anything.
I would like to see some of this information on a swedged wheel stud. Because it would be new to me.
Timmy390
Conway, AR
What years does this apply to? I've seen this issue on many a thread and always scratched my head as my 74 front drums came right off just as the rears do. I've had them off and on many times servicing the fronts when I had power drums. Even bought new drums form the "zone" and they went back on and off the same way.
Now I'm disc's up front.
Tim
vtboy51
vtboy51
I'm seeing this issues on my 1968 all stock.
Tim
The '69 I had no issues popping the studs out and seperating the drums from the hub. Scrapped the drums and used the hub as a spare tire carrier. Had to put some washers on the studs because the lucnuts would bottom out before the wheel was tight with the drum missing. Reused the old studs after hammering them back in.
Quick & Dirty
I took these drums off my '74 when I did the disk swap many years ago. They have the swedged wheel studs to hold the drum in place.
I'd guess those that aren't swedged on have had the drums replaced previously.
broncodriver99
Glen Allen, VA
Those look just like the set I took of of my '73. I did notice the pattern around the studs but since they went straight to the scrap pile I didn't put much thought into how they were different from the other sets of Bronco drums that I have worked on. They must have been the original factory drums. Interesting, great pic.
Timmy390
Conway, AR
The drums on my 74 had nothing like that. They must have had been replaced somewhere along the way before I bought it so i didn't have to deal with the issue.
Tim
That's just the knurled portion that is a larger diameter then the threaded portion of the stud. Studs typically have a .6XX" knurl with the ½" threads.
