670Holley TA problem
davq
El Paso
I have a Holley 670 TA on a built 302. And I was wodering if any one knows or could explain to me why the carb wont idle, even after the choke opens. it stays around 2300 rpms and will wind down after I mash on the skinny pedal a few times, but as soon as I drive around it goes back up to 2300, and stays there. Any help or advice would be appreciated.
DAVQ
Buldozer
Bronco Virtuoso
God's Country
I have the same carb and it idles fine so it must be a problem unique to your carb....sorry I can't give you the exact problem.
broncnaz
Fast idle screw/linkage is probably hanging up. Might be due to the fast idle being to high usually you want it down around 1500 rpm.
recoiljunky
Dothan, AL. USA
1st- Put your location on your profile info. Someone local might be willing to look at it for you.
2nd- Check your return springs. Are they strong enough?
3rd- What kind of throttle linkage do you have? Factory or throttle cable?
4th- How long has it been doing this? Did it start after a recent modification?
ep67bro
Bronco Junky
Easton, MD
My 470 TA will hang up above idle too. If I just lift the gas peedle a little it kicks down to idle. I think my linkage on the carb itself is hanging up. I may try a firmer return spring.
JWMcCrary
same here, and that just reminded me my rear float is still adjusted all the way down from OCBR last year.
broncnaz
A lot of times there tends to be extra play in the choke linkage thats where the issue usually is with high idle the play in the choke linkages causes the fast idle cam and crew to come in contact with each other thu causing the high idle. Usually just backing off the fast idle screw will cure it.
If you suspect its the throttle return spring next time it does it try pulling the gas pedal back if the idle goes down its probably the throttle return spring if it doesnt its the fast idle setting.
D
davq
El Paso
Thanks to all that responded. I will certainly try all the things mentioned. I am in El Paso, Texas. And recently new to the Bronco scene. I appreciate all the advice. I will let you know what the culprit is.
Thanks Davq
D
davq
El Paso
Problem solved: it was a combination of two things. First, the throttle linkage was hanging up, turns out it needed a little lubricant. Second, the return spring on the carb was a little soft for the application. A quick trip to the local parts store for a new carb return spring kit and some spray lube and finally a steady consistant idle. Thaks for the help everyone.
DQ
