69 Bronco Instrument Cluster issue
Cevy
I have a 1969 bronco and the instrument cluster, specifically the Fuel, Temp, and Oil arent working. Ive read other post that mention they are controlled by the Instrument Voltage Regulator. I have a new IVR coming, but not sure that will fix my issue as this will be my second IVR. My issue is that im getting 12v to the IVR, but when the IVR is attached to the back of the instrument cluster with the screw, my guages wont work, but when i remove the IVR from the cluster but keep the wire plugged into it, my gauges pin to the right.
Okie69
You don’t want to apply power to the ICVR without it attached to the cluster. It gets ground through the case. I would try it again with the new one and put it all back together before hooking your battery back up.
Cevy
Cevy
thank you so much for the reply! So the new one came in, unhooked the battery, removed the old one, installed the new one and still no go. know what else may be causing this? i cant imagine ALL the gauges are bad... Ive checked all the fuses, unplugged and replugged the wires including the ones with the harnesses, and no luck... the Ammeter seems to work fine..
Gsxr7000
Is it always a must to unplug the ICVR ? I just installed one and didn't. Gauges not working going to try a ground strap to make sure it's grounded well.
No it’s not. As long as the ignition switch is not turned to ON or ACC there is no power being applied to the ICVR.
Are you using the original electromechanical style, or the modern electronic versions?
Either way, are you verifying the power coming out of the regulator? You said you had power going in, so you know that the ignition switch and wire are good.
But have you checked the power coming out?
usually not… But it’s not impossible either. And it’s also not impossible for you to have bad sending units at all three locations.
Have you tested anything else?
No fuses involved here. But with these old trucks it’s never a bad idea to check them anyway.
Taking them out and cleaning things in the fuse panel almost always makes things work better.
That’s good news, but it’s on a completely different circuit so is unrelated to the other three gauges.
Viperwolf1
electron whisperer
It sounds like the gauges are working as they should. You should use an ohmmeter and see what the senders are saying.
