hollowch
Everything stock except 35s 4.11s and 5inch lift. Is there any way to adjust fuel mixture for daily driving?
The odometer and speedo will be off by equal amounts if you did a gear change and did not change the speedo drive ger accordingly....
Should be, but I guaranty they are not.
They are both driven off of the same (speedo) cable, so they should be off by the same amount. Otherwise there is a mechanical problem in your odometer.
First off the speedo is not mechanically connected to the cable. It's magnetically coupled. That adds a point of error to the system.
2nd, with a driven speedo gear that has only 17 teeth the best accuracy you can expect is going to be +/- 3%. That degree of accuracy is also stated in the factory service manual. Speedo came calibrated within 3% and odometer came cal'd within 3%. However, because of the speedo gear limits, the speedo could have been + 3% and the odometer could have been - 3%. All within factory specs. Now add bigger tires/lower gears and use the speedo to determine which new speedo gear you need. You get lucky and get one that gives you 0% speedo error. What does that do to the odo error? That's right, you increased it to 6%.
How are you measuring your milage?
Since you post no details on what you have motor wise then we have to assume the factory 2 barrel 302.
If it were mine I would put a vacuum guage on the motor and look for a steady vacuum reading. I would check and replace vacuum hoses and the carb gaskits in order to get a steady reading. I would then adjust the Idle mixture screws equall amounts to get the highest steady vacuum reading.
Then I would change the timing at Idle to 12 - 15 degrees advanced. The more the better as long as you dont have pinging, starting issues or overheating. after you adjust the timing you will need to reset the carb all over again. I would not run regular gas especially if you are running fuel with alcohol in it. Make sure you have a clean air filter. If you truly have the stock engine you have the worse case to try to get milage. If you try to fly down the freeway after 55 mph your just dumping fuel on the ground. You dont have enough engine power and torque to pull the 35" tires and the 5 inches of lift and your gearing in the axles are not enough. The poor tired engine is trying to pull an elephant up hill wearing flipflops.
Most people here are trying to get better milage on the freeway but your worst milage is at idle through 3rd gear on the street. Make sure the engine is doing the best it can in those areas first and your poor gear ratio to tire size is a real problem there. Advance in timing will help there.
Alright well what would you suggest changing the ratio to? I was under the impression that 4.10's were ideal for 35s. Here check it out for yourself http://www.4lo.com/calc/geartable.htm
That 10+ degrees is right on. Factory specs were in the 6° to 8° range over the years if I remember, but these things love about 12° initial in many cases. Some don't, but most do.
And welcome to CB fatorino. Thanks for chiming in.
