'94 F-150 engine swap?
YellowBronc
Bronco God
I have a line on a 1994 F-150 that's been wrecked and the engine is still good. (Knew the guy that owned it) I tried to do a search to see if this engine will work without problems and can't seem to find the answers I'm looking for. It will be swapped into a '75 Bronco, So if anyone has some insight, my ears are open.
Is this engine a possible "roller cam" engine? It will only be used as a long block to replace what's in the Bronco now. This is what concerns me in the swap:
1) Will the Bronco distributor work in the F-150 block? (ie, is the F-150 a roller or regular tappet cam?)
2) Will the Bronco flexplate work on the F-150 block. (The F-150 is a clutch and the Bronco is an automatic)
3) Since I'll be swapping timing cover out from the Bronco to the F-150 block, can the harmonic balancer be swapped also to enable the timing marks to be on the correct side as well as being able to use the 3 bolt bottom pulley? Or does the F-150 balancer have to stay with the engine?
Any other things I need to consider?
It's also been discussed on using the EFI but we do not want to use it. The Bronco will retain the carb setup for now. This swap has to take place within a few days and without serious problems. It is used as a daily driver for employment and can't be down for very long. This engine is practically going to be given to us and this is the only reason I'm considering it.
I appreciate any help and advice for this swap.
rjlougee
You would get more answers if you told us which engine it had. It could be the 5.0, 5.8 or 4.9 inline 6 cylinder. Either one *could* work, but the 5.0 would be the least amount of work, replacing the 302 in the Bronco.
Here are the answers:
1. If it's a 5.0 then it'll be roller and you'd have to change the cam gera between the two. No big deal, if not a 5.0, then no.
2. If the F150 is a 5.8 then yes, otherwise, not without rebalancing the flexpalte.
3. Balancer has to stay.
Go with the injection. Spend a couple weeks understanding the wiring system and you can install the whole thing in a weekend.
Joe
4byford
Yucca Valley CA
A 94 F-150 with a 351 (F4TE block) will also be a roller and will require a 351W specific distribuot with a roller cam compatible gear.
YellowBronc
YellowBronc
Bronco God
Sorry, the F-150 has the 302/5.0 in it.
So what is being said is that I'll need to find another flexplate so that it will work with the C-4 in the Bronco? and the balancer can NOT be swapped over from the Bronco's 302, right?
The balancer is not interchangable. Pulleys won't be either (3 vs. 4 bolt)
Flexplate I don't know.
If you decide to run a carb, even if it is just until you figure out the injection, don't run the old 302 distributor. It will wipe out the cam gear. Get a distributor for an '85 mustang GT with a 4V and 5 speed. It is roller cam compatable non-computer distributor.
YellowBronc
YellowBronc
Bronco God
Thanks all.
I thought this might be a simple swap but I don't have the time to deal with little problems to get it going. To many other things to deal with at the time to just add more things to the plate. Might as well do some saving and rebuild to do it right.
Again, thanks for all the info!
