Cut from a previous post of mine....
"Was going to verify TDC so I can check my lash but the piston stops I bought won't reach nor will my compression tester. Is there an adapter to reach down into the spark plug hole? Also, now that the engine is buttoned back up, it's very hard to turn by hand using a socket on the crank bolt. When I was about to start the rebuild, I could turn by hand quite easily. to observe the internals operating. I've read this is normal for a fresh rebuild - what do ya'll think? (All new bearings and rings, new cylinder hone, reused pistons, arms, crank, cam. Had heads refreshed using existing parts except new valve seals and valves/valve ports lapped.)"
So I pulled the oil pan and loosened the main and rod caps, recoated with WD40 and it's still hard to turn by hand (140-150ft-lb). Nothing is binding. Heads are still on and plugs are out. I did not loosen the rocker arms but some are so loose between strokes that I can turn the rocker arm nut with my fingers - which is why I wanted to verify I did the lash correctly before really buttoning it up with accessories and valve covers. Dang it - now I'm going to have to recoat everything with assembly lube since I've been doing all this
Does anyone see anything glaring that would cause this? I did not plasti-gauge but have just ordered a kit to verify tolerances. Even so, loosening the bolts should have told me if there was a bearing clearance issue by making it spin easier. Piston rings are not oversized, cylinders are stock, with just a hone job and taper/roundness check. Piston ring gaps are within tolerance.
On another note, by observing the location of cylinder 1 - I can say that the timing marks on my factory balancer are correct for TDC.
