Rox Crusher
- Dec 13, 2008
- 2,773
So I swapped in a used 5.0 EFI motor from a 98 Explorer.
Bought it off of Craigslist from a guy who got it out of a low mileage (80k) salvage rig. Course that could be total BS as it was in his garage.
Took the pan and the intake off and it was super clean inside so I decided to use it as is.
It has had a mild vibration since start up and I now want to try to resolve it.
The motor runs nice, without any miss or timing issues.
It isn't that bad at lower RPMs but when I put the RPMs up it gets dramatically worse, especially in first gear in the 4R70w.
I have ran it with the tranny and transfer case in neutral without any improvement. I have ran it with the serp belt off......again, no change.
I took the inspection cover off and checked torque converter bolts which are all tight. The flex plate was new at install and I am pretty certain I bought the correct one, but I can't find the receipt. I took the following pics of it and I am hoping some expert can confirm that is indeed the 50 oz version. Wondering if it might have been mis-boxed or made wrong.
The weight is about 4.5" long x 1" wide x 1/2" tall.
The dampner had never been off and looks to be in good shape but I suppose I will be taking it off to make sure.
Meanwhile, can anybody confirm the flex plate based on the pics and info provided ?
Any other suggestions are certainly welcome.
Thanks in advance !
Thanks in advance !
