Seems oddly high strung to me. Not that it’s a bad motor, and not that it doesn’t probably still put out more power down low than a stock motor did, but that particular one appears strangely biased a little to the higher rpm range.
For an engine that isn’t developing huge numbers, it seems to ramp up slowly. Torque is in the 350 range and fairly level, but only after 3000 RPM. Horsepower is down in the 300 range which is kind of a sweet spot for a low rpm motor really, but shows a long ramp up as well.
Maybe the bottom end below 2500 on that chart is because it’s just coming up and it might be the way the dyno operator was working the controls? But if not, it’s actually fairly weak down low and doesn’t come into its own until 3000 and above. Finally peaking horsepower at 6000 RPM-ish.
Still, if it’s a good deal and you can keep it tuned well induction wise, it could be a nice upgrade from stock.
Wait for a lot more opinions however. A lot of people have built motors similar to this in recent years, so should have more direct experience than I do.
It’s actual peak numbers look very similar to the blueprint engines “bronco” model engine. Don’t they?
Any way to find out what cam is in it?
