Distributor Advice/Suggestions
SeaVee
It’s distributor time on my 302 build. It’s in late 80s block with a mild cam, a little headwork and a holly 500 CFM carb (1848-02, i believe).
Looking for advice on what would work best for this set up. This truck will be more of a daily driver, mall crawler. We are restoring it back to original condition. There will not be heavy off-road on this one, maybe some sand and that’s about it.
Thanks in advance for any suggestions
56f100bbw
Tucson / lakeside AZ
I wouldn’t do an MSD run ready I had a circuit board go out in the bottom of the distributor. They are big bucks now, not ford Dura spark most common easy to get
nvrstuk
PNW
IF you want dependability you literally only have two choices:
1- DUI Davis Unified Ignition distributors and parts are the MOST reliable and that is why they cost the most. ( aslo mentioned directly above this post)
2- Ford OE Duraspark. Simple, OE tested for literally hundreds of millions of miles. Work great, just make sure the module you buy is an OE, MOTORCRAFT unit not some POS rebuilt junk. If you don't buy Motorcraft (used will work fine) you might as well buy an HEI unit that many here will suggest. These HEI units last until they leave you stranded. Great for the Broncos that get used 1x/month is all.
gr8scott
Not stock but I'm real happy with the DUI HEI set ups.
I run their Ford Duraspark rebuild.
It triggers a HEI module.
I daily drive my Bronco.
nvrstuk
PNW
[/URL]
It's a DUI. :)
They make good stuff.
I would guess some other company has to make something that is reliable (one would think) but all I've witnessed, worked on and heard stories about for 40 yrs are all the other brands out there (except Petronics) that fail when used. Who cares if it's cheap and has fast replacement shipping if you're on vacation or hundreds of miles from home and the 75 dollar ebay/Amazon special fails.
One ruined day, one tow bill easily pays for quality.
S
SeaVee
DUI site says 4 month lead time. Pertronics has been suggested to me as well.
m_m70
Prescott AZ
I'm running a Duraspark out of a stock '76 and keep a spare module in my console. Both modules are Motorcraft. Happy with the curve and haven't had any issues in a dozen or so years.
fordguy
This is what you do if you have duraspark. My friend had one on top of the other on the fender well. They are not as easy to find nowadays.
badandy73
Broncoholic
No love for the MSD pro billet on here? Paired with a 6A box makes for a solid setup, been running one for several years now with no issues.
nvrstuk
PNW
M= My
S= Spark
D= Disappeared
No offense if you're having good luck (hope you continue to) but the acromyn is accurate. :)
I know guys that run MSD but they have issues. Others I'm sure have good luck.
I'm real happy running my points distributor through a TFI module firing an E-core coil. All stock parts.
The distributor driven gear must be compatible with the cam material. Are you for sure running a flat tappet cam?
Next up is the curve. The advance rate. An emissions tuned distributor isn't great for power of drivability. Springs and limits do vary depending on who did the tuning.
bmc69
I've installed & used Petronix for decades on dozens of boats & vehicles.
Excellent product and inexpensive.
Same here. I've used even more Mallory Unilites. However....the quality of the electronics in those is really sketchy these days. Never trusted MSD....I miss Jacobs...
nvrstuk
PNW
I'd forgotten about Jacob's. :) I ran their stuff back in the late '80s.
I believe Unilite got bought by Mallory.
Mallory got bought by Holley (same as MSD)??
S
SeaVee
I bought the engine from my mechanic who had it built for a project he never finished. Was professionally built by a reputable local shop. Never been fired up. Has some modifications, below is the cam card. Just looking for something compatible that won’t break the bank.
m_m70
Prescott AZ
What did your truck come with?? Pre-electronic ignition I would go with the points distributor with a Pertronix module dropped in. If it has a Duraspark ignition, I'd keep that.
Just make sure the gear material is compatible!! Swapping the gear is easy. I think these are the best options for the cost....Just my 2 cents which is worth just that :geek:.
