Anyone got the old school stock air cleaner with the cold air intake hose running up to the grill? Mine is a 71 which did not come with a stock setup like that - I have headers = alot of heat, I have all the parts to convert it over to a 73 assembly to allow the cold air aspect. the cold air hose runs up going thru between solenoid and battery - I have no opening for cold air to come thru where the end of cold air intake hose tube bolts on. Is there an opening up there on the later models 72, 73 and later, that came outa the factory with this type of air cleaner setup? It appears mine will bolt to a solid wall with no opening for cold air to enter the tube
