- Jun 29, 2015
- 865
So for a couple of weeks I have not been able to drive the bronco due to business. Yesterday I had to go get Chandler from football so I uncovered the Bronco and fired it up and drove it about 2 miles where my Range is to check on something. I finished and got back in Bronco and drove about 1 mile where an intersection is and....brake to the floor.... I have about 1500 miles on it since complete rebuild....every drivetrain part and brake part brand new... Well after slamming e brake down to floor and driving into ditch to keep from rolling into intersection, I was able to limp it home. Today while checking the system I thought one of the fittings going into proportioning block had sprung a leak. The rear brake fitting. I removed it and when I did I realized that the steering shaft had been rubbing it and had rubbed a hole in it. I never once noticed that it was against the shaft and when I installed it I know it had clearance but sometime when fiddling with something I must have pushed it over and caused the rubbing. I went and bought a new straight line and custom bent one to fit much better and these lines are harder metal than the ones that come in the disk kits, but not as brittle as the stainless ones. It is all fixed and I was able to let Chandler get more time behind the wheel today on way home from football.
I cringe to think what would have happened if he was driving yesterday and this would have happened while he was driving on the busy road we have to travel.
Bottom line. No brakes = bad ju ju
Even if you know they were installed correctly most are softer tubing and very easy to bend out of shape while tinkering on something else. This is now gonna be another preflight checklist item of mine
Yall be safe out there
Chuck
Chuck
