luvmybroncoman
So heres the latest and greatest after Bill and I worked on it for about four hours today. First we disconnected the fuel pressure regulator to get a nice healthy 42 psi. Also hooked up a fuel pressure gauge to monitor the pressure while driving. Guess I should explain the symptom first for those of you that don't know. Truck starts and runs great for about 15 to 45 minutes. Then it seems to lose fuel pressure, but still wants to run. When you put it
under load it runs like crap too. Well after hooking up the FPG and driving this is what happens. Under load the fuel pressure will dive to almost nothing, let off the pedal and it slowly creeps back up. But not back up to 42psi, more like 10. Not good. So we came back to the house and started thinking. Lets change the fuel pump and see what happens. Did that took it for a spin and the same thing happened, back to the house. Okay now what, lets try the grounds and make sure everything is tight. The ground for the fuel pump was horrible. Cleaned it up, take for a spin. Yes!!!!!!!!! !!!!under load going up a hill pedal to the floor maintaining 42psi. Turn around head back for house, up another hill damnit!!!!!! !!! loss of fuel pressure same problem again. Add fuel to make sure it's not that, not that. So here's
where it's at. Replaced fuel tank rerouted return line, new fuel pump, cleaned grounds. My next thought is the fuel pressure regulator, but I'm not real sure about that. Any input or suggestions.
Dan
Dan
