Another EFI purchase question
WSM29
Okay, So I am thinking of getting into the EFI world and want to start collecting parts for a 351W that I plan to swap out. I am in no rush with this, and most likely wont pick up the Windsor from my parents in IL until after this next deployment. I do want to start collecting the right parts though! So i saw this and went to check it out.
The guy has an 89 Foxbody that originally had 4 cylinder in it. He pulled an 88 Lincoln 302 EFI and swapped out the 4 banger. So the harness would be an 89 and the engine would be an 88 Lincoln. He has the upper/ lower intake and a MSD dizzy and coil. The car still has the harness in it and I wasnt sure where the ECU is. I took plently of pics and figured I would hit you guys up on what will work for a 351W EFI. I dont think the lower will work from some previous questions, but what about everything else. He is pretty much giving it away, so if anything is useful let me know. If not ill keep on looking!
EFI Guy
TheEFIguy@gmail
BFE
The PCM should be in the passenger side kick panel. The lowers will not swap. You will either need to do the BC adapter or find a Lightning lower ($) and GT-40 Upper.
Is this a mass air setup? If not I would do the mass air conversion for sure.
Viperwolf1
electron whisperer
Some good hardware like the harness, fuel rail, IAB, TPS, coil. Manifold and distributor are good for a 302. Can't see what size injectors but they are probably smaller than 19 lb. Throttle body is tiny.
WSM29
WSM29
UPDATE- After doing some reading "not enough yet!" and trying to add up all the numbers for a rebuild on the 351 plus doing the EFI I have desided to just do an EFI for my rebuilt 302 in my bronco now. I am really wanting to do a MAF conversion instead of the speed density, but honetly I dont understand how to spot or how to source the difference between the two. I can get my hands on some GT40 uppers and lowers, as well as some Mustang HO uppers and lowers. I know a lot of guys are running the GT40s on their 302s. If I wanted to use the RJM Harness, I still have to pull a mustang computer though correct? Any perfomance differences or install differences with using the Mustang HO or the GT40 setups?? Thanks in advance!
WSM29
WSM29
I can pick up this setup for $150. Hes got the rails, injectors throttle body.. Ect.
KyleQ
I searched Colrral and my u-pull yards and saved tons of money - wait and rebuild the 351W, the power is soooo worth it. I've got lots of info in my build thread -
That setup woudl cost half that from a pick and pull yard or better yet, lots of people sell that stuff for cheap locally on your Mustang boards...
WSM29
WSM29
I picked up a RJM harness from this site. I also found this gem in my local ads. I can pull whatever I want from her. Looks to be a good donor from what I can see. Should be a MAF system. Any thoughts?
KyleQ
Why would you pick up a RJM harness and then post pics of a perfectly complete Foxbody?
Just throw money at it until it runs...
WSM29
WSM29
Not trying to build a harness... Read enough articles talking about the hours involved in a building the harness. I liked the idea of the RJM so if I get the time down the road to build a 351w I can swap it out fairly easily. I wasn't trying to break in a new 351w and try to get EFI working at the same time. To me that just spells death to a flat tappet cam.
KyleQ
Yeah, I can see where your worries come from, but funny enough I see more people asking and having problems with those harnesses, but maybes its just the people who buy them vs the folks who do it their selves and actually learn about the entire setup, but I'm just calling out what I see.
I built an engine, did the harness, Explorer serp, and a host of other things and broke in the new engine - it ran perfectly. I let it warm up, took it out for a light cruise. Let it cool down and then proceed to beat the shit out of it to seat the rings (I had a trail riding event, no holding back).
That is a roller motor though - but you can do it however you see fit. If you are worried about it, just drop a carb intake on in and break it in, toss the EFI intakes on it afterwards and fire ti up and enjoy the fuel injection revolution.
WSM29
WSM29
I am heading down tomorrow evening to pick everything up. I know I need the complete upper and lower intake with all the sensors I can find. Its an 89, So I should be able to pull the computer. I am going to pull the MAF sensor and the intake out of it, along with the coil and dizzy. Can I salvage anything else off the engine that will be useful in the bronco? Will any of the front parts work, like the pullies or brackets for the alternator and power steering? My 76 does have PS now. Thanks again!!
Viperwolf1
electron whisperer
Get the valve covers too. They look nasty but you can clean them up. and it will simplify the crankcase venting. The front drive system will work but The explorer stuff is a lot shorter. Get the inertia switch from the trunk.
ilovemaui
Pacific Moist West
I agree with the RJM harness because you know you're getting a good harness and it will be one less item to troubleshoot later. The RJM harness is built specifically for the Bronco conversion. If you can afford it you won't regret it.
I am not a big fan of the GT40 heads but they are better than most Ford small block heads. If you can afford to go aftermarket I'd do it. AFR or Trickflow.
WSM29
WSM29
I will grab the valve covers as well. I am currently running the E Street heads with roller rockers. I know some folks have had issues with them, but I don't see the bronco hitting 5500 rpm too often. I've read about a spring kit that makes them even better. The only issue I am going to have to fix are a few cross threaded sparkplug holes. Keep the info coming guys! Thanks again!
