my bronco has a severe lean to the passenger rear side. The frojt passenger side is lower than the driver front as well but not near like the rear. I replaced the body mounts a few months ago with no luck of fixing the lean. If you drive it for a while it's like the lean works itself out somewhat and then once parked for a while it's like it sags itself back down. I've read and heard about the c bushings.
Another thing that throws me off is that there is a gap between the bottom of the tailgate and bumper on drivers side that gets smaller as the tailgate moves from driver to passenger side. The body mounts did make the pass side gap a little bigger between tailgate bottom and bumper but still not as much of a gap as on drivers side.
Previous owner had lift put on
