lsukevinc
I hate to start another thread that has been beat to death, but I have a few questions on what is going on with my bronco. I have a 76 bronco with a 3.5” Duff suspension lift and 2” body lift. Like most broncos this age, once you reach 40 MPH, the bronco wonders all over the read. The previous owner said the tie rod ends were up graded to that of a F-150. The tie rods and seems to be tight and in good shape as well. The ball joints are were replaced recently and are still appear shinny and in good shape. The steering wheel has minimal play in it while the bronco is not running, so I think my steering box and steering shaft is in decent shape. I jumped on the front bumper and the steering wheel did not move. It has the stock pitman arm and the track bar has been lowered with a welded on bracket that seemed to be in good shape as well. The track bar and the radius arm are almost perfectly parallel, only 1 degree apart according to my dial gauge. I checked the alignment with tape and a tape measure and it was off a little, I will set the front to have a slight toe in.
I have a magnetic dial gauge and I took a few readings. I know this gauge will not be perfect, but the driver’s side show maybe 3 degrees caster and the passenger side showed 0 degrees caster. I assume I will need new c bushings? I guess the only way to find out for sure is to bring it to an alignment shop and have the bronco’s measurements checked out. Finally, the tires may be an issue as well. The tires are 32” Mickey Thompson MTZ’s and they only have 25 psi in the front. Look at the picture I included, does it appear they are cupped really bad? Could the tire cause part of the problem I am having?
Any suggestions are realty appreciated.
http://i1274.photobucket.com/albums/y435/lsukevinclsukevinc/IMG_1917_zps145c08b2.jpg
