I just made a run in mine.
I saw IAC Steps anywhere from 0 at a low idle, up to 130 at various times during my drive. I have a high idle situation in the driveway where it sits at 62 for a split second then fluctuates either way corresponding with the idle rpm. IAC Learn is at 16 step.
It doesn't start that well either.
I am learning all of this but have spent a lot of time the past week reading, adjusting, driving and trying to tune my bronco. I have been out of commission for a couple of months but getting back into it.
You might have already answered these but can you tell me the following?
Are you waiting until the temp is at least 170 before making any adjustments?
If not that is important.
Since you are running the FCC you need to change the PWM Low Flow to 40. Go to Main Menu, #6 - Go-EFI Pro Tuning, Go to #12 Fuel Pump Control, then #7 PWM Low Flow - enter 40. Press OK - this will upload the setting. The default is for running the in tank or in line pump.
Next - if your truck is warmed up at idle - what is the idle set at? Is it there or is it high? Getting this and the IAC, then driving the truck will help.
Let me know where you are on idle and IAC with the truck warm and we can work on it.
Also - have you looked everywhere for vacuum leaks? This will throw it off. If you did not weld in the O2 bung that can be a big leak point.
Sorry if some of these questions are dumb or basic but it is important to look at everything.
Once the idle and steps are good at idle we can adjust hot starts, and other problems you are having.
Don't give up.
