Chris, Maybe you can give some input on the hot start problems. I have had several issues that FiTech had me re-flash to fix. Recently my FiTech started to not want to start when hot. I can drive it all over hell and gone with no issues (except the backfire on decel that Fitech says cant be fixed) until I turn it off. Then I have to crank for 2-3 minutes to get it to start again. IAC at idle is always 7 to 9 and it starts first crank when cold or has sat for 10-20 min. Im ready to yank this POS off and go back to a carb. Any thoughts?
Jim - here is some more info - maybe try the suggestions on crank fuel adjustments and let us know if that helps, hurts or does nothing?
IAC Steps:
Turn the driver’s side throttle adjustment screw IN (clockwise) half a turn to start with, with that done turn the key on and go to dashboard and find TPS and make sure it reads zero. If not, then shut the key off and wait for the numbers to go black then turn the key on again. Once that reads zero start the vehicle and find IAC Steps on dashboard. This number needs to be within 3-10 at warm idle. If the number reads zero then slowly turn the screw OUT (counter clockwise) until the IAC steps reads between 3-10. If the number is above 10 then shut the vehicle off and turn the screw IN as stated above and repeat the process until the IAC steps are between 3-10.
Cranking fuel adjustments:
With the key on go to the Go EFI Tuning menu, find Crank and Warm up. There you will see three cranking fuel selections. For cold starts add or subtract fuel from Crank fuel 65f, for hot starts add or subtract fuel from crank fuel 170f. Changing these settings should help with your start up issues along with setting the IAC. A good starting point is to change the settings in intervals of 10 to find which way you need to adjust the system to work better.
Accel pump/ Fast Accel adjustment:
If the system is having a hesitation or bogging issue, and you IAC steps are between 3-10 at warm idle, then your next step would be to adjust the accel pump function to increase or decrease the fuel added on acceleration. To start with turn the key to the on position and then find Go EFI Tuning on the main menu and press enter. Then find Accel pump and press enter. You will see a menu with multiple different settings, you need to focus on the Accel pumps (20f, 65f, 170f) and Fast Accel (20f, 65f, 170f). These setting adjust how much fuel, at varying temperatures, the system injects when you accelerate. Accel pump is used for any normal throttle input, Fast Accel is for any fast throttle inputs or Wide Open Throttle.
Hesitation: If the vehicle has a hesitation (when you step on the throttle and the engine does hangs and/ or almost dies and then suddenly take off) this normally is a lack of fuel so you would fix this by increasing the Accel Pump (for normal throttle input hesitations) or Fast Accel (for fast throttle or WOT inputs). You would make changes starting in increments of 10, to the temp range that you are finding the issue to reside in.
Bogging/engine loads up/slow to respond: If the vehicle is bogging (when you step on the throttle and the engine is slower/sluggish to come up to a higher rpm) this is normally caused by over fueling. To fix this you would need to reduce the amount of fuel it is injecting as an accel pump shot. To do this this decrease the Accel Pump (for normal throttle input hesitations) or Fast Accel (for fast throttle or WOT inputs). You would make changes starting in increments of 10, to the temp range that you are finding the issue to reside in.
Choosing a cam selection:
Cam selection is based on vacuum load of the engine. Cam 1 is for 15Hg or above, Cam 2 is for 10Hg to 15hg, Cam 3 is 8Hg to 10Hg, Cam 4 is 8Hg to 6Hg. These are estimates and you may need to switch between them if the vacuum load is between two different cam settings to get the engine to run better for your application.
Idle Return:
If the engine is not returning to idle quick enough for your liking or is dropping too quickly and killing the engine then you may need to adjust the rate at which the injection system comes to an idle. To do so you need to go to Go EFI Tuning, then find and select Idle Control. Once in this menu you will see several settings, the only one we are going to work with is Decel open IAC. This number should be at zero as a base setting, by going negative you are reducing the amount of time it takes to return to Idle, and by going positive you are increasing the time it takes. Normal procedure of adjustment is to add or subtract 10 to start with and then adjust it to your liking or what the engine needs. Then once the setting is input save it to the ecu by pushing the joystick IN, the handheld will show Send To ECU Successful. Once this is done make sure to go back to the dashboard and turn the key off until the numbers clear out on the value side. This shows that the system has saved.
