Does anyone currentlybhave any of the fitech systems in stock?
L.R.
L.R.
For dizzy don't use a Pertronix. I put an Igniter 1 in a dead Unilite and got no spark. Emailed FITech and they said Pertronix is not compatible. Put an MSD in and it fired right up.
Pertronix works just fine with FITECH as a stand alone distributor, what they are telling you is its not compatible with the FITECH timing control.
I hear you, I got conflicting statements on the distributor question. Basically any two wire distributor can be used with the FITECH timing control. It's basically a built in MSD box. FITECH can also control an actual MSD box. You can use any distributor you want with whatever ignition system you prefer as a standalone. If you want FITECH timing control you need to use a distributor that they recommend. I was told that a Duraspark distributor would work with timing control so I bought that setup and changed from pertronix ignitor iii. I've since read on here that they don't recommend Duraspark for timing control. I have the email still where they told me I could use it. I'm just running the Duraspark right now without the FITECH timing control setup. You have to lock out the distributor and you have to get a distributor that can use a phase-able rotor. Right now I'm happy to just have the factory electronic ignition.
How much timing control does the GoEFI 600 offer? It apparently is a pretty nice setup once dialed in correctly. As far as adjustability I'm not sure. But several parameters can be changed to customize the results for different engines etc.
I have a 351W, so if you have 302 bear in mind you will need a different one.
I bought MSD-8578 I also bought the adjustable rotor MSD-84211. The adjustable rotor I think will work on any of MSD's distributors.
From Bryce, Not exactly a list but this is what he sent in an email
Brian,
The simplest, cheapest, and possibly the most reliable is a HEI large cap distributor. Companies like Speedmaster and Top Street Performance have very economically priced units. MSD HEIs are also an option as well as any of their other distributors. As I’m sure you know though, MSD parts aren’t the cheapest.
Bryce Cegielski
FiTech Fuel Injection
12370 Doherty St. Suite A
Riverside, CA 92503
Phone – 951-340-2624
bryce@FiTechEFI.com
