Anyone use Mercon V?
C4
Anyone using "Ford Motorsports Mercon V"? I went into the ford dealer looking for Type F and they told me it's obsolete now, Mercon V has taken it's place. I told him I had a 1976 C4! He said, that if the bronco was in their shop they would service it with Mercon V........
Any ideas?
Thanks!
1sicbronconut
I'll have to check this out at work on Monday, I know that Mercon III went away but I think we still stock the old school ATF.
Dave
I know that the 4R70W in the 2000 Explorer specifies Mercon V and does not recomend ATF or Merocon III.
That sounds about like the mentality of a dealship.
Type F is type F
Mercon has an evolution to it and has evolved up to the 5th level.
It would not surprise me that the dealer uses Mercon-V in everything, even vehicles that state the warranty is void if anything other then XXX is used. Dealer service departments are not as perfect as some people thing and I have seen some unscruplous dealing go on in dealer service bays. Stuff that (as now working for the manufacturer of the vehicle) are horendous attrosities to the care of a vehicle. I have known of cylinder heads installed with an impact (to torque wrench to be seen), spark plugs installed into aluminium head via impact, prybars on all sorts of odd places. Complete disregard for proper spec lubrication in all fluids of the vehicle. conventional oil poured in next to the tag listed as synthetic only. Any grade, any weight motor oil in the engine as long as the dipstick reads full. What ever the most economical bottle of compressor oil they have for any A/c system compressor change.
Short answer, don't trust the dealer. Especially with anything that old. You are probably asking for products that went out of service before half the tech there were even born.
garberz
Bronco Influencer
Conejo Valley, Ca.
I would look for type F. Most auto parts stores should have it, although it is getting harder to find. Type F has zinc in it. Thats what the older Ford transmissions were designed to use. I used Castrol type F ATF. The AutoZone carries it. Here's a quote from BwoncoHowie.
The swami eh...;) I dont wear a turban on my head.
I'll post those remarks again.
My choice will continue to be type F for the C-4 as long as it remains available. Dexrons, CJ types and Mercons all have friction modifiers in different different capacities. Friction modifiers change shift characteristics to a smoother application of friction materials (ie. clutches and bands). Newer formulas containing friction modifiers will cause the transmission to have softer shifts but the chemical properties are made to withstand and remain stable in more severe temperature conditions. The newer formulas designed for electronic transmissions also have the absence of Zinc. Zinc being present in ATF is vital for longer gear, bushing, and bearing life. Type F fluid cannot take the heat like the newer formulas and will require changing more often, but the original formulation still contains Zinc. I am willing to make that choice for firmer shifts and longer life of the components that have constant metal to metal contact. I can compensate for some heat breakdown with the addition of a transmission auxiliary cooler.
There is also an ATF additive that contains Zinc in the formula along with other synthetic and petroleum properties that will extend the life of the fluid as well as protect the fluid from excessive heat. I have used this stuff since day 1 on my AOD. The original transmission now has 251,000 miles on it and is still working fine in my daily driver.
http://www.lifeautomotive.com/Products/ATFP4001.asp
With the addition of a transmission auxiliary cooler you can extend the life of your fluid and other components inside the transmission.
When it comes to choosing oil for your newly rebuilt C-4, you should go with what your rebuilder's warranty recommends. That being said, the previously mentioned is strictly my humble opinion. ~BH~
22213evl
Rio Rancho N.M.
Broncobowsher Short answer, don't trust the dealer. Especially with anything that old. You are probably asking for products that went out of service before half the tech there were even born.
there ya go
you can find type F everywhere even walmart
C
C4
I live and Southern California and can't find Type F anywhere? I've checked Napa, Kragens, Pep Boys, Ford Racing, Ford dealer, am/pm's, 7-1, AAMCO, transmission shops, you name it........I guess they forget about us folks driving the old school cars around.
garberz
Bronco Influencer
Conejo Valley, Ca.
Auto Zone, Walmart. I don't know how close you are to an Auto Zone, but they carry it. You can buy it online and have it shipped to your door if you want.
http://www.autozone.com/R,1028429/store,5713/initialAction,accessoryProductDetail/initialAction,accessoryProductDetail/initialR,1028429/initialselectedZip,91360/shopping/addToCart.htm
Viperwolf1
electron whisperer
Maybe CA has deemed it to be a hazardous substance that causes cancer in Navy sonar affected whales. Yes I have seen the stockpiles getting smaller at parts stores over the last few years. Not enough demand.
I would believe that out of California. A state that as of Jan 1 2009 banned the sale of catalytic convertors. I am sure factory replacments are OK, but the aftermarket supply is now locked out of the state. Why? That state is just messed up.
FordFanStan
CA
Type F is type F
I could not of said it better myself. The dealership is the last place I will take any of my vehicles, luckily I work for a 7 time Senior Master Tech that now has his own business, but man does he have some stories about the dealers lol.
They still produce Type F trans fluid, find it and use it.
Wouldn't surprise me.
Last week, I was helping my roommate order some new cats for his Lightning, Summit already had them locked out for sale in Ca., Jegs didn't so Jegs it was. FFS
73stallion
Eugene, OR
it's all about trying to legislate older vehicles off the road. i haven't seen type F in years, i think it was replaced by type FA
broke_okie
I live in Central Cali and I buy "Type F "at Walmart . I buy it a case at a time and it only costs $1.68 quart.
