ntsqd
heratic car camper
I owned two square body 4x4 Suburbans successively. Both had 3.73's and wore 285/75R16's, The first one had a TH400 (2.48:1)/NP208 (2.62:1) in it and the second one had a 700R4 (3.06:1)/NP241 (2.72:1) in it. Both would go "there", but the second one was far easier to drive there.
If all you're going to do is drive it on the street then you don't want the wide ratio option. If you are going to drive it in the dirt then the wide ratio option is the way to go and the on-pavement shifting soon won't bother you.
FWIW the real test of the trans cooling system may well be in the dirt, in first - low range.
