AODE swap: Do I need 1" body lift???
Faster Eddie
Seattle
Need help please,
Got the AODE bolted up to the motor, D20 behind it, but need another inch to make Tom's crossmember to work.
Question, do I HAVE to put in a 1" body lift or can I do something else to get the clearance I need for the D20 to floor gusset?
Any and all advice is appreciated!
Eddie
I have done it without the body lift. But there was a bit of butchery and clearancing of the floor to make it happen. I don't know how the Tom's crossmember sets the transmission, I made my own crossmember.
But I will say a 1" body lift would have made things a LOT easier and cleaner.
WILDHORSES
USA
This quick trick might get you there. Assuming the crossmember used 4 bolts like stock, you can drop it down and just use 2 bolts per side. If you are trying to maintain ground clearance you will loose 1-1 1/2" at the bottom of the D20.
Jim
Faster Eddie
Faster Eddie
Seattle
Jim
Now that is an interesting proposal. Would drop my driveshaft angle a bit too, which would be helpful since the AODE is going to make it higher with the extra overall length. Hmmm
Thanks for the help!
Faster Eddie
Faster Eddie
Seattle
Thanks for the input here. Really don’t want to butcher it up.
Thx for the help!
pcf_mark
Maybe this does not apply but I have a 4R70W with an NP205 on a custom crossmember and did not have to cut my floor. I did have to extend the hole for the t-case shifter forward a bit I think but nothing crazy. i could have done it w/o any cutting but the shifter did not move as nice. The key is an automatic column to avoid all the shifter on the floor nonsense, I had to cut and re-weld the shift rod and shifter arm on the transmission.
Faster Eddie
Faster Eddie
Seattle
Nope. Different deal on floor clearance. Same deal on shifter (twin sticks) moving rearward. Thx tho
Faster Eddie
Faster Eddie
Seattle
The 1" lift went in smooth! Clearances are great fir the D20 and I have room under the hood for a proper air cleaner on top of my Sniper. Bonus!
Thanks again for the input folks!
