Colliedog3
I have a bronco with a 351w, ax15, Dana 20 combo. Also has 4:11 gears, Detroit locker and 33s. It has a brand new center force clutch, new pilot bearing, new throw out bearing, new driveshaft, as well as a freshly resurfaced flywheel. This is the second time I’ve used this clutch and have had chatter both times when starting off in first gear. I went all over the truck re torquing motor mounts, trans mounts and u bolts. I also checked t case and rear end for play and had no noticeable play. Was wondering if anyone had ran into a similar thing and what the solution was. Clutch has 100 miles of easy driving and just started doing this.
