- Dec 8, 2010
- 16,289
In the cylinders....ton's of anti-freeze came out when we drained the oil.
Imma say blown head gasket or cracked block.
Thanks all, the 80MPH spec was probably too aggressive for highway driving but I want the power if I need it, let's revise to 65-70...running 33x12.5x15's w/ a 3.5" lift, regular steel hood.
I think Nightstick's on the right path...gonna pull the head and check the gasket..fingers crossed that's all it is.
p.s. all paid up on my life insurance.
I vote head gasket. Intake gasket is a possibility, but when mine was improperly torqued and leaking I was getting fluid dripping off the backside of the motor, not internally. It's certainly possible it's an intake gasket, but I would think you'd get some leaking outside of the motor as well.
Regarding the engine builder consider looking into mediation in your area before using an attorney and going to court. I'm a volunteer mediator for our county and our success rate in settling cases is about 75-80%. It is no cost and voluntary but lots of people use our services to avoid hiring attorneys and incurring expenses. You can find out if it's used in your area by looking up dispute resolution or mediation services.
80mph is easy. A rebuilt mostly stock 302 will push a bronco past 110 no problem in my experience.
Getting an explorer 5.0l longblock from a junkyard would be the cheapest. Put your intake on, replace the distributor gear with a brass one to match the roller cam, and potentially have it back running in a weekend.
my bet is on head gasket as well. question, did it ever overheat? don't have to answer that if you don't want to![]()
It was constantly running hot.
Hello -
But it's a bronco and wind noise and those big tires can make any highway drive at those speeds tiring - 70 with the soft top is bearable (and I'm sound proofed too).
Just to clarify the builder built the complete Bronco or built just the engine?
Hey guys,
So I got burned REAL BAD by a "bronco builder" and after only 300 miles I've got a heap of problems and the biggest to date is water in the engine. The builder is radio silent and won't return any of my calls so his 3-year / 30,000 mile warranty is worthless. So...I'm considering biting the bullet and purchasing a new crate engine that comes w/ a real warranty vs burning money on tearing the engine apart to find the issue only to find more issues down the road (mom & pop build).
Can anyone suggest a good long block crate motor that's reasonably priced? this is a weekend fun car that's mostly being used on regular roads plus a some highway driving. Needs to be able to do 80MPH and sound like a beast. The POS is a 302 so whatever will swap easiest preferable. Thanks in advance for all your advice.
If you want your sanity back while highway driving a Bronco put in a set of foam ear plugs when you travel highway speeds. You will suddenly be able to have conversations with your passengers, the drive will be so much better and you wont be so tired when you get to your destination. And you will be able to actually hear the radio or CB.
