Was that Performance Unlimited Lars?
And not to take away anything from Anthony's stuff, but I prefer a Heim at just the upper end myself. Like BCB sells
The lower bushing keeps at least some isolation going on, and will also keep your trackbar from twisting on the rod ends. Not a big deal on a straight bar of course, but with a "kinked" bar to clear the diff housing, that rocking motion just doesn't look right.
I can't say from an engineering standpoint just what would be wrong by having your trackbar twist on it's mounts. It just didn't seem right to me.
In the case of the BC bar, the upper having a rod end now, still takes any angularity stresses off the bar, mounts, bushings, threads and joints, should allow the lower bushing to last half of forever (the lower lasts a long time anyway), should need less servicing, and would still be tighter than your existing bushings.
I know that the '76/'77 oval upper bushings should, by design, move more than the earlier round ones, but in my mind you're better off with no side-to-side movement at all on a trackbar. And with the new steering setup you have now, I don't see any dire need for an oval shape of the extra play it offers.
If you don't have an adjustable trackbar, you probably should. If for no other reason than fine-tuning the centering of the axle assembly. If yours is perfectly centered already though, and you don't feel the need for a new adjustable bar, then just replace the upper bushings with polyurethane ones and see what that does. Should tighten it up pretty decently.
In my experience, even that 1/8" of play is more than enough to cause some wandering. Maybe not as severe as you're experiencing, but the worn bushings or loose mounts always made for noticeable wandering in my daily-driver.
Even a lower bolt that had broken loose from it's weld and had less than an eighth inch of movement made for a very consistent wandering even on city streets.
