Balancer boo-boo
tasker
all knowing of nothing
NH
Crossed over my original Harmonic balancer with the casting number E4TE-A3A or so i thought....got this and does NOT look like it's gonna worky.....anyone with some insight? i have a 73 mongrel with a later engine in it not installed by me....
Ford motorsports has an adaptor to space the short to the tall. Don't know how much that helps you.
tasker
tasker
NH
Might either go with an aftermarket (summit) or reuse....pulley alignment is at issue....
tasker
tasker
NH
I know right? i've poured through the Ford catalog and with the casting number on it i thought it would be easy street......but no,
Viperwolf1
electron whisperer
What's the number? What other info do you know about the motor? Being a truck part number it could be from a 302 or a 351w. The big difference is going to be the balance.
tasker
tasker
NH
Old one is a 50 oz... had gotten a 28 and waaaay different. i'm thinking mustang 302 early 80's maybe? looking for block castings tonight....I've had it four years and never had to take much apart other than the timing chain last summer...
tasker
tasker
NH
anyone else care to chime in? i can't be the only one that's run into this?
LSUpete
Well, until you find a casting number for the block, it's gonna be tough to get that damper precise. I know....big help huh.
My suggestion is to contact Damper Dudes and show them these photographs.....if they're willing to review it with you. Ultimately, it might be better just to send them your old one and let them provide something that matches.
:cool:
70_Steve
Old Guy
The PO of my 351 engine was on a quest to get the most fan spacing he could. He found a waterpump pully that set back an inch from stock. He then had a machine shop turn down the face of his harmonic balancer an inch so the pulleys would line up. Luckily I knew this going in, so when I had my engine rebuilt (the first time...:cry:) I gave them the new harmonic balancer and told them the face will need to be turned to match the old one.
My balancer(s) look exactly like your old one. I think I still have the old one. I can check the casting number when I get home if you like.
tasker
tasker
NH
That is what i think is happening, if you could that would be most awesome!
broncnaz
The casting number from you old balancer says its off a truck engine. I'd take your new balancer back and see what else they come up with may 84/85 truck. I dont have my balancer book close or I'd look it up.
rcmbronc
Tomah WI
I am guessing that the old balancer was off a car and the new one appears to be from a truck. Maybe look at a balancer for a 89 Mustang. Not sure.
70_Steve
Old Guy
Makes sense. My 351 is originally from an 86 Econoline, and that's the balancer I bought. Again, my new one looked like Taskers new one, and my old one looked like Taskers old one.
tasker
tasker
NH
i've tried 351's 302's and everything in between....cars and trucks, vans, forklifts, golfcarts, log splitters.....
Viperwolf1
electron whisperer
Another option, which is probably cheaper, is to have the old one rebuilt.
