UPDATE - WELL CRAP!! After 50/50 advice of “leave it” vs “get it out,” I got the old threaded pre-load screw out. However, in the process I boogered up the top threads on the C and can’t get the new screw in. Anyone know the size of the hole and thread pitch? And where to get a thread tap to fix it?
Can I re-use the old pre-load screw when replacing ball joints?
I am replacing balljoints (D44). I cant seem to get the old pre-load screw out of the inner C. I has soaked it in lube (PB Blaster and WD-40) and heated with torch but it wont come out. One problem is the spanner tool I have - it is brand new but it does not "lock" into place and just slides out when I put any sort of force on the wrench. I'll keep trying to remove it but I'm curious if I can just re-use. I know one way to find out is to install knuckle and hope I achieve the desired pull force on the knuckle, but I'd like to know for sure before I do that. Anyone??
