- Joined
- Mar 8, 2007
- Messages
- 81,985
After swapping in a 351w, 4r70w, and atlas 2 a few years ago using a mustang injection set up I have never been able to track down a random stalling issue I was having. Coupled with the tuner not making time to finalize the tuning, I decided it was time for an explorer injection swap.
I purchased a 98 explorer from a fellow member (thanks ngsd) that had been wrecked and also sat in his dad's backyard for a few years. (I probably killed 50 daddy long legs haha) It started right up and we were able to load it on the trailer.
I got it home, pulled into the shop, up on the lift and blew it apart. I pulled the trans, and both harnesses. I wouldn't consider getting the harnesses out easy, I commend the people that do it in the junk yard, no thanks!
After watching EFI Guy's videos for a few dry runs while usually falling asleep on the couch, I took the laptop into the shop and starting cutting some wires. Since I had already installed a 4r70w that was an older case with the analog range selector, I had to do some extra pin swapping on the transmission connector as well as use two of the front o2 heater circuit wires, hopefully it works like it should!
Engine harness is pretty simple, I didn't end up opening any splices, I just snipped the wires and heat shrunk them. Lots of chasing wires all the way through the harness when de-pinning the ecm connector.
I got the firewall harness all split out into relay box side and into the cab side. I decided that I was going to try and use the black firewall connector to pass through the firewall. I de-pinned what I needed to, kept the wires I was saving and added the wires I needed from the other two firewall connectors, the brown and the gray. I haven't fully terminated yet so I can make sure my lengths are all correct.
For the Relay/fuse box I decided to go with an amazon unit that seems pretty nice. I need to decide on a mounting position so I can get my wire lengths figured out get everything terminated.
I went to the junkyard and scored everything I wanted. I grabbed a Windstar ECM mount, as well as an Escape mount, and a spare 98 computer.
I decided on the fully enclosed Escape mount, I liked that the fact that I could fab up a bracket to hold the rear of the box up as well. Got the hole cut in the firewall which was a good time with the big 351 right in the way. Just waiting on my rivnut tool to arrive so I can mount it for good.
I am at a point now where I did have some questions that I couldn't quite pin down the answers to. I figured I would ask them here for others that might happen to run the same set up I have.
I have a centech harness that has the 10g yellow wire that I have been running on the battery + post of the explorer alternator for years. I had some of the mustang harness components loomed together with that part of the body harness. When I pulled the loom and tape away, I found a burnt up splice about a foot from the alternator ring terminal. From what I understand this was the incorrect place to put this wire with this alternator? This wire runs directly to the fuse panel. So with the explorer harness, if I wire up the alternator like Garry does with the short yellow wire fused from the plug directly to the B+ post of the alternator do I need the centech yellow alt wire?
Also in my body harness I have all of the sending unit wires hooked up to all my gauges in the dash. So if I were to hook up the single wire coolant temp, and oil pressure in the explorer harness and the wires from the centech harness that is just being redundant correct? You only need to use one or the other.
Here are all the pictures in sequence so far. Looking forward to driving this thing on the street without worrying if I can make that left turn in time or not!
Look forward to seeing the progress....
