Bent Ford 9 Housing???
SSDDBRONCO
Los Angeles
Here's my dilemma.
I have upgraded 31 spline axle shaft with Set20 bearing, after every 1000 miles or so somehow my bearing may be getting damaged as they start to leak diff fluid down the end onto my rear passenger tire. I have replaced these bearing 3 or 4 times and the same issue every time.
I called some axle shops and they said it sounds like my housing is bent. Does that sound about right? If so is there any way to check myself if it's bent?
Kev
Boss Hugg
I'd venture to say there are very few straight housings on the road. I'd say it's entirely possible.
Yeller
Rogers County Oklahoma
They are all “bent” some. The bigger question is which part is leaking? The area around the axle shaft or the housing? Is the bearing showing signs of abnormal wear?
As for checking it can be done in the truck but it's not easy, takes some creative thinking and a lot of measuring. Really need an alignment bar to check in the vehicle and know 100% what is going on.
Do you drive in a lot of sand? Could be as simple as sand eating the seal too
SSDDBRONCO
SSDDBRONCO
Los Angeles
Well after replacing the bearing 3 or 4 times I would assume the housing. I drive it on the street and then after roughly 1000 miles they start leaking. At this point Im thinking of just buying a new housing %)
JSBX
I had two different sets of set 20 bearings leak after a few hundred miles. I started putting RTV around the outside of the bearing seal before installing. Haven't had any leaks since. Just make sure the seal edge and the housing or clean and oil free.
I knew my housing was bent. Inset the axle until the splines start to engage (my case a detroit locker) but the bearing isn't in. push the axle left and right, up and down. How even is the bearing going past the housing end in each direction? That can tell if the housing is bent.
If the housing end is welded on crooked the shaft will go in straight but the bearing will be twisted. Don't have a quick way to check for that. Probably rig something with a dial indicator and the axle not fully locked into the housing.
Boss Hugg
When you pull the axle do the splines show wear that indicates the splines are not running true?
Timmy390
Conway, AR
The bearings seal inside the "cup" on the end of the housing. If the cup is damaged inside as in not smooth, pitted or like mine were "oblonged" due to past bearing failures, the set 20's will not seal.
I had to change my cups. Cut the old ones off and weld on new ones. cost me $65 as I recall. I didn't have a jig so I welded the housing to a metal frame and used the center section and the old bearings/axles as a jig. Made many many measurements prior to cutting so I could get everything back to where it was. No leaks or issues in 8 plus years
Tim
SSDDBRONCO
SSDDBRONCO
Los Angeles
Ya I did that after I changed them a couple times and it lasted for a little but then started to leak.
Oddly my shafts slide in really easily and doesn't give me any hard time. Maybe my ends are bad ?:?
No I dont see any abnormal signs of wear or odd.
Tim
My ends looks to be pretty smooth and no dings or anything like that. The only thing i can say is that when i put the race into the end, i can spin it with my hand, is that normal or should that race be real tight and snug?
BanditBronco
I would say you are on the right track. I was having bearing and sealing issues as well, put in a currie housing from WH and they went away. I still do the RTV on the outside of the seal trick in the new housing just in case. I'd be willing to bet your problems would go away if you put a new housing in it. If you want to run another stock housing, I would swing the empty housing by the driveline shop if you have one in town you use. They should be able to check it for true for you.
At $595 for the housing, we're offering Free Shipping on our #8689 Super-9 housing at the moment. You're not that far away from us, so free shipping might not be as big an advantage as it would be to some. But hey, every little bit helps sometimes.
If you're right around the corner from Currie that's a nice advantage as well.
If you do decide a new housing is in your future, check the prices and features and see what's out there that you like.
Then again, our swap-meet is just a couple of weeks away too. A fun road-trip might pay off big time!
But compare brakes too. Ours are for the big bearing, big brake setups. If you currently have small brakes (though it does not sound like it) you'd need to work that out too.
Good luck. As said, it's quite common for them to get bent up over time. Luckily it's not more common, but it's still a thing that a lot of owners have had to deal with.
In the meantime, if the bearings look good still you could try the silicone sealant tricks to see if that gets you by for awhile.
SSDDBRONCO
SSDDBRONCO
Los Angeles
Ya it's looking that way. I found a shop that will check if the housing is bent for like $30 bucks so Ill have them check it out before ordering a new one just to be for sure.
That's the exact housing I'm looking at! If I need a new housing I'll definitely be ordering one from you guys... wondering if i can get a discount from you :D haha
Timmy390
Conway, AR
As I recall I had to "tap" mine in with a rubber hammer. Not sure I would call them "TIGHT". The race should not spin.
Tim
BanditBronco
Also might check that the vent isn't plugged. A plugged vent can cause the pressure in the housing to push out the seals.
Forgot about vents, good call. On your new housing or if the old one ends up straight, I would run two. I have put two on every housing I have built in the last 10 years, its always good insurance. A lot of times if two is a no go, I will bore out the stock vent bolt for good measure.
Definitely check that. The bearing housing should not spin freely. It can be forced to spin, but only with effort. If it's spinning in the housing end just from turning the axle shaft, it's too loose.
Might be building up heat from it, might be distorting the seal from it, might be something else like a clogged vent (very common in fact) or whatever.
So yep, still some checking to do. Gotta' get to the bottom of this mystery!
Johnnyb
Flagstaff
This was a useful thread for me. I was 50/50 on my housing, but this post convinced me to order a new one from WH, considering they are on special and all (;-)
Decades ago I burned out a passenger side wheel bearing near Ely Nevada, and ever since then that bearing is not lasted more than a few thousand miles. I also suspect my housing has meant for the same reasons as listed above, plus I need to pull the pumpkin to fix a leak anyway.
Thanks everybody!
JB
Sent from my SM-N981U1 using Tapatalk
Thanks JB. Should be a nice upgrade for you. Hopefully bearings last a little bit longer now!
If you are either not lifted, or are lifted and already have tapered shims between the leaf springs and the old perches, verify your pinion angle before you button it all down permanent-like.
The new housing "should" have it's perches welded on at such an angle as to make the shims unnecessary. But you know how that goes.... Every Bronco is different!
