Yes, that what got me thinking when I seen '31' option on the third member, doesn't cost any more for the extra splines...
Yep. Free on the differential end, but extra for the axle shafts. But well worth it to the peace of mind.
However, truth be told, there are plenty of 28 spline axles running around and living happy and healthy lives still. Just depends on your right foot and other things.
But "if you like having fun, go 31."
The stock 28 spline axles were more than good enough for 99% of Broncos with open differentials. However, those with factory limited-slip diffs, and especially those with aftermarket lockers, started feeling the pain right away when they were hitting the harder trails. Lots of shafts sheared off at the splines.
Some thought that was why Broncos were banned from the Jeeper's Jamboree for so many years. But I think it had more to do with broken steering boxes and the lack of replacement parts, than it did the much more easily obtained and replaced axle shafts.
But most events tended to have Jeep parts handy, and virtually zero Bronco parts. So it was fabrication-city or long trips to town with high hopes.
What is this 'open rear' and 'lunchbox' you speak of??
An "open" diff is a standard one with no properties for sending power down the axle with the most traction. An open diff may have gotten it's name because the center carrier (the differential itself) was actually open and basically "see-through" on most differential designs.
But that's only a guess. Never heard why it's called that, and the term was around long before I was.
The "lunchbox" lockers are the ones like Aussie, LA/Lockrite and Detroit EZ Locker, and others that internally mimic the Detroit Locker but are just bits and pieces of them without the outer case. So they're less expensive and easier for a consumer to install without any specialized differential setup knowledge and tooling.
The idea was to install the units into your existing stock differential to get a locker. They're considered weaker for that reason because they're only as strong as your existing open case. But hey, even Detroits break!
The term was meant to describe the fact that you could install one on your lunch break. Hence the "lunchbox" moniker.
But I LOVE doing doughnuts....
. Thanks for all the info but think Im going with limited slip right now until I can save some money for Air Lockers down the road..that is if I still want them....
You won't unless you get out in the dirt more often. Although, like a winch, it only takes that one time!;D
