Best EFI engine for the Bronco???
kholding
Las Vegas, NV
Next question,...I have a blank canvass as far as engines go... I am looking for an EFI engine to put into my '73 Bronco project and have read soooo many things about different EFI engines that can be used, have been used, are being used, etc... What are the best candidates for a solid EFI engine swap? Mustang 5.0, Bronco 351 w/GT40 intake, etc...I have been looking all over Craigslist for a donor engine but now I want to make sure I am looking at the right vehicles/years, etc...Thanks.
I'm thinking that the single best donor is a '96 to '02(?) Explorer/Mountaineer.
It's got the roller motor, the P heads, the most desirable serpentine drive setup, and one of the more desirable intake systems.
I'm sure there are some things that are not optimum, such as having to make a few minor mods to the intake for a change of sensors if you're using an aftermarket or Mustang harness, but that's pretty minor stuff.
The only real additional purchase would be a TFI distributor and whatever harness you wish to use.
Either that, or just do what a very few have done. Leave the DIS (distributorless ignition) intact and make the ECU and harness work within the new parameters of the Bronco chassis.
Other than that, it's pretty much an open question. Any of the Cougar/T-bird engines, and the '94/95 Mustangs have one combination or another of the advantages of low-profile intakes and decent serp setups. Some are MAF and some are SD though, so you have to be aware of what you want and need first in those cases. But the Exploder is the only one I know that seems to have it all. Almost.
Then again, the P heads can be a pain for some due to header issues. So there's that to add to the mix.
ransil
Its the one you get cheap or free..
next best one is the one that that has everything you need and you can see it running
motor, accessories, wire harness & computer.
broncnaz
best over all is probably the mustang setup as you can make mods to the engie and the computer will adjust to most if not all of them.
If you just want EFI and no real engine mods then any of the EFI engines are fine with maybe the truck/van engines being the exception as the intake manifold is to tall for a bronco you have to switch it to the car style. but easily done and usually the cheapest option around.
I would put the explorer setup/ engine on the end of the list especailly the 94 up versions there computers need to much outside input. Much less the P head issues.
basically few EFI swaps are 100% from one vehicle except the mustang swaps so usually your going to buy a wiring harness, probably a ECM, at the very least.
overall power wise I'd go with a 351W with a car upper intake and mustang ECM.
ztoolman44
Farmington, Utah
Where are you located? I have a complete 97 explorer engine and all the FI stuff from a crown vic in addition. Changed my plans, now going with a diesel. Willing to let it go pretty cheap.
G's Baja Bronco
Sunny SO CAL
91-93 t-bird cougar is 5.0L HO, and not as beat as mustang engines. get the AOD from it also.
I am using a 91 cougar HO, it;s aod with 4R70w Internals, NP 205, got the GT40P heads from a 99 explorer and the intake from the explorer also. I am going to use a 5sp 91 stang compute rand harness.
IFLYHOOKS
Clarksville
X2 with Dirt's recommendation, except I would make it a '96 or early '97 Explorer with straight GT-40 heads, not "P" heads. I have "P" heads and finding headers that work + getting custom exhaust done was a challenge. Completed, but a challenge.
ztoolman44
Farmington, Utah
Shoot me an offer. I picked up the explorer engine from a t-bone wreck. Someone else took the transmission and rear end. Never heard it run so my plan was to do an overhaul on it for good measure. Truck had just over 100,000 miles. The other stuff includes intake, fuel rails, harness, computer, etc from a town car. Think it was an 89. Have to take a look. I may be headed to Vegas in a couple of weeks on my way to the NASCAR race in Fontana. Perhaps could drop it off.
If it were my blank canvas...
351 Lightening, mustang harness and electronics, Explorer front dress.
Upgrades (first package all at once) roller cam, heads, MAF, injectors and a custom tune to make it all happy.
Package 2, 408 stroker kit and another tune.
Package 3, it just wouldn't be right...
Why my choices?
Explorer front dress is easy, best fitting accessory drive and it works while being affordable.
Lightening engine? Start with a 351 and a great intake that will fit under a hood. Happens to come with better stock heads.
Mustang electronics and harness? The lightening is a truck engine with a slightly glorified truck EFI, the mustang stuff is extreamly popular and easy to understand and upgrade.
Next step up is a simple hot rod package and as a whole package it works as a single part will not do much and could actually be detrimental alone.
kholding
kholding
Las Vegas, NV
Thanks everyone. Broncobowsher, I like your rationale...so I should find a nice 351W and add a GT40 head, find a mustang computer and harness and that would be my starting point?
I would start with the lightening engine, even if the cost is a little more. Already has GT40 heads. Make sure the intake is included, those are hot items right now. No intake, no deal. That is less stuff you need to put together.
fungus
Kaneohe Bay, Oahu
I'm w/ Ransil on this one. Got a '90 mustang GT 5.0 w/ tubular gt-40 intakes, bbk 65mm throttle body complete from the base auto hobby shop for FREE. She's waitin on the funds for a 347 kit. Already got the rest of the efi stuff & a set of edelbrock performer heads w/ 2.02 intake & 1.60 exhaust valves. Exploder serp to go on her as well.
