- Feb 1, 2004
- 1,965
Never took pics. There are so many amazing minds here I feel my mod was mediocre at best. I will snap a pic and post.Got pics? Or a link to another discussion you've shown them in?
Thank you.Thanks for the pics! I think it’s a great idea. Looks like it works too.
Nice tribute dash.
so how are the magnets rated? i mean how did you know what strength would work? that looks like a pretty good solution but my bronco is all undercoated under there and i imagine it would take a pretty stout magnet.Took a couple pics.
yea good point. i wonder how expensive the good magnets are?Depending on the thickness of the undercoating, you are right. It would make a big difference and so you would generally want stronger magnets.
However the computers and fuse panels aren’t exactly heavy and with four of them used as feet, I think the holding power is enhanced greatly.
Still, a thick and deeply textured liner is going to definitely cause you to think more about it.
Easy enough to test though. You could get some cheap magnets at Harbor freight or wherever and just try one on the liner coated metal.
thats exactly what i keep going through in my head. unfortunately my lack of knowledge keeps getting in the way. my motor is out right now so ive been weighing the best way to go about it. my problem is ive spent alot on my eb and ive tried to go the extra mile on everything. i really want this to be a clean set up. being unfamiliar i know there are things im gonna miss or screw up and then afterwarsd think man i wish i hadnt done that. i keep thinking if i know where one harness is i can work the other around that but which first. and its been so long since i striopped it down i cant even remember where the wires need to run. that may be in the instructions but if it isnt where is a good source to find the info?Magnets are still very cheap. Even expensive rare earth magnets, if you buy the cheap ones are not very much money.
You can get a really strong magnet for next to nothing.
Even those little hanging magnets at Home Depot are extremely strong if you get the right ones.
No matter which one you install first you should “think” of them concurrently.
It’s often easier to install the vehicle harness when the engine is out, or at least expedient to do so while you’re waiting for the engine to go in. That makes it a good choice to do the body harness first.
But you can’t do it properly without at least thinking about, and knowing where each of the connections to the EFI harness are going to tie into the body harness.
Really what I’m saying is that even if you’re not physically installing them at the same time, you think you are because you’re thinking about each one at the same time. You may even start with the body harness and lay the engine harness on there while you’re doing it to get an idea of where the cut in the firewall is going to be with the grommet, or where the ground is going to attach, or where you’re going to put the Bank of relays.
All that kind of stuff keeps your brain power on a high-alert level at the same time.
If the engine is already installed then I would put the EFI harness on completely so that you have an actual working knowledge of where each other component is going to go.
The BAP sensor just needs to be out-of-the-way somewhere, and the ignition coil wires are long enough so that you can either mount it to the engine or literally over on one of the wheel wells.
Or even the firewall.
So yes, lots to think about. But once you’re in the middle of it it all starts to make more and more sense each step you take.
thanks a bunch italiano, ill check them outGo to K & J magnetics web site and they have the ratings of the neo magnets. They are surprisingly stronger than you would think.
A member just posted yesterday I think where his is on the driver’s panel of the indent. Was looking for suggestions on where to mount the ECM that didn’t interfere with the defroster ducts.
The explorer mount has proven to be very popular, but I don’t know how that would work with the older computers.
Maybe 904Bronco or one of the others has a comment on that.
no mine is fully mounted now, though i think im gonna have to pull it to do this wiring job. im nowhere near that flexible.lol. is there anything i shoud take note of or measure before i pull it out?Is the dash at least still out of the truck? Or is it fully mounted?
Can’t say about the clearance for the ductwork though. There’s not much back there usually.
Got a couple of pictures of the back of your dash?
