Best Stock Suspension setup?
Blue71
Those of u who have added new STOCK suspension back under their Broncos......what setup are you running? Looking for a really nice smooth ride. Also what shocks did you use to get the ride just right, did u use a 4 degree "C" bushing? Let me know...thanks,
Blue71
Justin@WH4x4
If you are doing power steering, just go to the 4° and get some good caster in it. The factory spec was very low for the manual steering.
gray gables
when I re-did my suspension I ran stock springs, wish I didn't, man they have a bounce to them. I did do a dual shock set up up front, major difference adding that.
rguest3
Very happy with WH 2 1/2" lift with Bilstein shocks. Ask WH if the Front spring rates are the same with the stock height. Rear will have 10 Leaf instead of 11, I believe, so they may be a little softer. Still, this would be much more comfortable than stock springs from factory.
...did u use a 4 degree "C" bushing?
Just to add to what was already said, the best advice would be to measure your current caster before deciding on which C-bushing to get.
If that's not an option, the it helps to know what year EB and if it's going to have manual or power steering.
With power steering, when in doubt, go bigger. But later model trucks (especially of the '76 and '77 vintage) usually had more positive caster built in, which is why the year can matter.
