Best stock suspension
jba6555
I would like to keep my 66 at stock height. I am sure that a new suspension package would greatly improve the ride after all these years. It seems like it has been awhile since this topic was discussed on the forum. I dont know if the manufacturers have changed their products in the last 10 years. What would you install with your funds if you were putting a new stock height suspension under a 66 with a 170 and a soft top?
That is going to be a tough call. 6-cylinder and soft top, about as light as they get. A lot lighter than most. Add in the rarity of stock height, most everything is for a lift. Ford was well known back in the 60s for having multiple different front springs for a single vehicle. Without chasing the factory parts books, I'm betting the 6-cylinder coils are lighter than the V8 coils. So even "stock" replacement coils will likely be wrong as they are based on the common V8 weights. I would expect the front to sit a little too tall no matter what.
As for the rears, there have been a lot of advancements in leaf springs. There are multi leaf packs that have better ride than stock. But in a stock height? That is likely to be a special order, not a standard part. This is going to take a talk with a vendor or two and see who is willing to work with you on this.
And shocks. Those have evolved greatly. At this point I even ask the shock experts what to run. I generically say to run a set of Bilsteins, but I can't tell you what valving should be used in a lightweight Bronco.
As for advise of "this rides good" posts you will see, consider that they are typically a heavier V8 Bronco and not your lightweight version.
bmbm
Moog used to have front coils for Bronco and if I remember correctly they listed coils for six cylinder but does not list that now. And whatever stock height front coils is available may be fine. I would guess about 60-80 lbs difference between six and eight cylinder motor. Considering your 66 might weigh around 3800 lbs with driver and tank of gas 80 lbs probably won't make and appreciable difference in front height. 80 is about 2% of 3800.
The weight factor has more to do with the spring rate. Lb/in compression rate, secondary factor being ride height. A lighter vehicle has a softer spring rate.
U13FL735
Are you wanting stock looking springs too, or just height? Front coils wouldn't show much difference, but those 10 pack leaf springs will, compared to the wimpy looking 5 leaf originals.
I'm just starting to look for replacements for my original 66 springs too, and haven't decided which way to go. Eaton Detroit Spring sells direct, and thru NPD and they're made in the US.....but the leafs are over $400 each, plus shipping. I was going to check local spring shops, but not too confident they could duplicate the original appearance.
Lawndart
Does anyone have experience with the Jeffs Stock height kit?
Back in late 2014, I purchased a stock height kit (#13753) from Bronco Graveyard. It replaced the harsh non-oem suspension that was on my Bronco when I purchased it. That was over 90k miles ago. Nothing negative to say and still performs fine.
J
jba6555
I am just wanting stockish height.
Double66
When I did the suspension on my roadster I installed Moog CC812 front coils which I think now are listed under a different brand on rock auto with Duff HD coil retainers. I put CJ Pony Parts rear springs with poly bushings and shackles from Jeff's Bronco along with all new hardware.
J
jba6555
How is the ride on those?
