Blinker and Flasher
rcmbronc
Tomah WI
Few small issues with blinkers. When the blinkers are on the headlights dim slightly as the blinkers flash. Engine is off so may just be from power draw. With flashers the front head lights blink on and off opposite the front blinkers. Cant remember if that is normal. Any issues or ideas? Original harness. May just replace harmess.
ksagis
Aspiring Bronco Guru
Headlights should not flash at all when hazards are flashing. Sounds like a ground issue.
rcmbronc
rcmbronc
Tomah WI
Yes it was rounds. I have a 76 but run the early front turn signals. No ground wire from them. Also a tube front end. So ran a ground wire from each lens housing to the tube then to frame ground. All seems good now. Thanks,
