Clean out all the bolt holes and put the head back on with out the head gaskit and make sure the head bolts go all the way down and clamp the head. Then you will be sure when you put the head on with a gasket it will properly torque down. Looks to me number 3 cylinder head gaskit was leaking. I always used Felpro printo seal head gaskits.
Well. I got lots of advice. Two school of thought, replace both or fixed what is broken. I opted for the latter. Replaced the bad side head gasket. I did a compression test and got ~120 on all cylinders. Got it all put back together and fired it up. So far so good. Did not drive it, just had in running in the driveway for a while. No leaks, engine sounded smooth. Time will tell.
Mark. I did as you recommended. Only swapped the bad gasket and used the old bolts. All of the intake gaskets were new, so I reused them. $25 and weekend. I also flushed the coolant system to get all of the mud and gunk out.
