- Jun 4, 2002
- 35,630
I would say at a very minimum start with an '84 block, that will get you a 1-piece rear main seal.
My choice would be the '94-97 blocks because they accept stock style roller cams
In the old days I would look for the early blocks because of shorter deck height (more power), allegedly beefier castings. But now I am older and wiser I will take a newer block that had more accurate cores placed inside during casting, one piece rear main that are generally leak free, and easy roller cams since todays oils don't work that great with flat tappets. The later EFI engine also tend to have minimal cylinder wall wear and a better chance of not already being rebuilt and bored too much. If you are looking at a stroker kit, the taller deck to keep compression ratios in a happy place are better.
