I've got nothing against the old style regulators either, but it sounds like you got a bum electronic one that time. I've never had that issue with them, but frankly have only bought two in all these years! The last one being long before we started having all these "import issues" with most of our electronic stuff.
To Sunset Kid (welcome to classicbroncos by the way!) it could be an all-of-the-above thing at this point. Your '70 is old enough now, that whether it's bone stock, has been lightly modified or is a total custom, at this point there are several things that can cause your issue.
The good news is that one of the common issues (a bad ammeter) does not appear to be the problem since you also see flickering in the lights. So for now, we'll ignore the possibility that you may need a new gauge and work on the rest.
How long have you owned the Bronco? Do you know how old the alternator and regulator are? Do you know if your main wiring is original or has been replaced? Do you know if your battery cables are original, or have been replaced? Is the Bronco very rusty at all? Even just with surface rust?
Grounding issues always seem to come up, as mentioned already, so I'll put a few details that I can think of on the list.
Aside from defective/failing parts here's a few:
1. Does your alternator have a good clean connection to the engine?
2. Does your voltage regulator have a good clean connection to the body?
3. Is there still a good ground wire between the alternator and regulator? It's a small one that uses the original rubber strain-relief connection on the back of the alternator and runs up to one of the attaching screws of the regulator at the body. Check that to make sure it's good. If the original connector is gone, then it's gone too unless someone replaced it.
4. Is there still a good body ground directly from the battery negative? Not just the main one to the engine block, but one to the body.
5. Is the connection between the main ground cable and engine clean and tight?
6. Are the battery cables older, or brand new?
7. While we're on about grounds, it's a good practice to add a ground strap/jumper between the back of the engine and the firewall. The original body ground connection at the wheel well is not always sufficient any more. The years of rust and paint can have a huge effect on how it all works. Hence the additional ground to the body from the engine.
8. Speaking of paint... Has the body been painted? if so, you may just help a little bit by scraping some fresh paint off underneath the ground connections.
9. The general condition of the wiring is a big deal. Any connection that has anything at all to do with the charging system is suspect. Even if it's not suspect, it's a suspect.
10. Usually not a problem, but certainly worth checking the main connector in the Black w/yellow wire just behind the ammeter itself. Pull it apart and check for rust/corrosion and make sure it's good and tight fitting still.
11. While you're at this electrical sleuthing, remove all five fuses from the fuse panel, clean them, clean the contacts, then put them back in. This may not stop the pulsing, but it helps the overall health of the system. The glass fuses build up a layer of corrosion that you can't always see, so this cleaning should be done every few years. Or more often if you live in a moist, or salty environment.
The most common item to cause the flickering that I can think of is probably the bad regulator previously mentioned. But since bad connections and/or bad wires can do it too, you may have some deep digging to do before you fix yours.
Good luck!
