broncofiresmith
- May 6, 2006
- 416
I saw this thread about trying a voltage regulator from 78 Granada I went to Napa to get one but it has a square plug instead of the round one. Did I get wrong one or do I need to change ends?
Early thread I saw in the archives.
"If you're looking at the stock gauge in the cluster, it's an Ammeter. Measures current flow, not voltage. Not that that really means anything about your question. The bouncing is the mechanical voltage regulator keeping the proper charge on the battery. Points open... points closed.... points open... etc. If you don't like the bouncing, I've read that you can replace the mechanical one with an electronic one from a 78 Granada."
