Brake booster help
Snake93
Installing a brake booster on my 74 bronco it has the factory 2 barrel carb
Where do I connect the vacuum line that run from booster?
badmuttstang
redneck grease monkey
AManifold vacuum usual back of intake manifold midway between the carb and the end of the intake. Might have a screw in vacuum manifold there for other accessories.
Hey Snake, welcome to CB!
What they said.
In case you have your PCV valve connected to a port on one individual intake runner, that's where the brake booster should be. The PCV is connected to the base of the carburetor or intake plenum to let all 8 cylinders share the load. The booster (and auto trans modulator when so equipped) can get away with a single runner.
Some of the Ford 2bbls in the mid-seventies models, starting in your year, had additional ports as well as the EGR valve plate. As long as your PCV is connected to a common source for all cylinders, your booster could utilize any extras if they're there.
Aftermarket carburetors often have two large ports. In those cases both the booster and PCV can go to the common ports.
