Brake conversion Master cylinder question
rpickard88
So I have have a 71 recently converted front brakes to disc. Is it possible or beneficial to replace the old drum Master cylinder with a later model disc MC
R
rpickard88
Disc conversion Master cylinder question
Bronco Biff
Possible and necessary for proper brake bias. The front caliper will require more fluid than the old drum wheel cylinders. What front brakes did you put on?
Glass Pony
Sussex County Delaware
Not sure which MC you have but if you are still going with manual brakes the later model disc MC will have the fittings on the wrong side.
I have a 74 and I am still using the stock manual MC with the residual pressure valve removed on the front brake port.
lagbolt
Not to hijack. What do you mean? How is it done? (stock manual MC with the residual pressure valve removed on the front brake port)
I have also had good success with a completely stock master cylinder.
As for the mysterious residual pressure valve, from everything I have ever seen it is nothing more than an orifice. Not a valve. Orifice can be used as a tuning aid to slow the brakes from applying too fast, adds a few milliseconds. Actually useful in getting the chassis to settle before slamming brake fluid to the wheels.
Every respectable reference I have ever read up on for residual pressure valves is for master cylinder mounted below the floor to prevent drain back (master cylinder lower than wheels) and not used in firewall mounted master cylinder applications.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've run front disc rear drums before with a stock MC without issue. Personally I prefer installing a MC with a larger reservoir and larger piston, but it's not necessary to do so.
broncnaz
If pedal travel has increased a lot then you may need a larger MC. Keep in mind that the larger the bore size the less pressure it puts out so the pedal can become harder to press to get the same amount of stopping power you had with a smaller MC.
Timmy390
Conway, AR
It's a heep forum but shows RPV and the removal of. the RVP is in the MC and is used to keep slight pressure on drum brakes.
http://www.jeepsunlimited.com/forum...roportioning-valve-for-rear-drum-to-disc-swap
Tim
Bronco Biff
I did the GM caliper swap and used a '77 ford f250 camper special with dual piston caliper manual brake booster that the lines and fittings are on the correct side. I also used the rear wheel cylinders for the same application that bolted right in. I think they were 15/16" vs. stock 13/16". The brakes feel really good and work predictably even in "panic" stops. I have a manual trans really like that they feel the same with the motor running or off which makes it extremely useful when coasting down step trails when all the oil goes to the front of the pan and the engine is better off.
R
rpickard88
Thanks for all the input guys, I have a "Jeffs Graveyard front disc conversion. I am in the process of piping the pro valve and have ordered the power booster upgrade. We will see where it goes from there.
