- Nov 28, 2011
- 794
Alright guys. I’m a little stuck fighting electrical gremlins. Here’s what’s going on.
I have headlights as well as front and rear turn signals the indicators flash at normal speed with the turn signal stock. The hazard switch turns on both sets of flashers but they flash quick and dim. I don’t have running lights or tail lights at any time, and I don’t have brake lights ever. I’ve also lost the gauge cluster back lights. I don’t know if that’s related.
What I’ve done. I started just trying to work through the brake light circuit.
-All fuses are good
-The red wire going into the brake switch has power.
-The brake switch closes and opens as it should (verified voltage passing through as well as checked ohm readings).
-Checked the red w/black wire that goes to the turn signal connector and then to the emergency flasher switch has power when the brake switch closes.
Jiggling the turn signal stalk or the wires running up the column has no effect.![64EB0D0D-E17D-48A1-85C3-CD915D977BED.jpeg 64EB0D0D-E17D-48A1-85C3-CD915D977BED.jpeg](https://classicbroncos.com/forums/data/attachments/877/877980-a431560a12ed06904525349695ab6924.jpg)
-All fuses are good
